Question about Tomtom ONE XL GPS
Home location keeps showing a different location. reloaded home address still showing a different location.
  • 699 Answers
On the TomTom One, this is impossible unless you have several maps.
Each time you switch to another Map, the preferences such as Favorites and Home addresses only apply to that specific map.
Let me know if it helps or let me know exactly what you are doing to change and set your Home address.
(hint: Change preferences -> Change Home location ?)
Posted on Jan 07, 2010
SOURCE:
How to set Konica Minolta copier online.
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 03, 2014 | Konica Minolta Office Equipment & Supplies
How to make Konica Minolta copier online?
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use. Mite also check to make sure you have the right drivers for the machine.
Sep 03, 2014 | Konica Minolta bizhub Office Equipment &...
Make Google my homepage
Chrome:
  1. Click the Chrome menu snp_2696434_en_v1 on the browser toolbar.
  2. Select Settings.
    • Add the home button to the browser toolbar
      Homepage button is off by default. Select the "Show Home button" checkbox in the "Appearance" section to show it on the browser toolbar.
    • Set your homepage
      When the "Show Home button" checkbox is selected, a web address appears below it. If you want the Homepage button to open up a different webpage, clickChange to enter a link. You can also choose the New Tab page as your homepage.
IE:
  1. Make sure you've closed all open tabs, then open Internet Explorer for the desktop.
  2. Tap or click Tools, and then tap or click Internet options.
  3. Under the General tab, enter the web address of your new home page, and then tap or click Apply.
FireFox:
  1. Open the website you want to set as your home page. If you want a blank home page, open a new tab.
  2. Click the icon to the left of the web address, drag it to the Home button, and release.
  3. Click Yes to set this as your home page.
Safari:
1. Click on Safari in your Safari menu, located at the top of your screen. When the drop-down menu appears, choose Preferences.
2. Select General from the Preferences menu, which is now overlaying your browser window. Once General is selected, you will notice a section labeled Home Page in the main window of the Preferences dialog.3. Directly to the right of the "Home Page" label is an edit field containing your current home page URL. In the example below, Safari's current home page is http://www.apple.com. To modify this address, simply erase the contents of the edit field and replace it with the desired web address.
4. Directly below this edit field you will see a button labeled Set to Current Page. Clicking this button will change your home page setting to whatever page you are currently viewing within the Safari browser.
5. Once you have completed your changes, close the Safari Preferences dialog by clicking the red circle/x located in the top left hand corner of the box.
Sep 19, 2013 | Computers & Internet
I Want BING HAS MY HOME PAGE
The is done differently in different browsers. The three most common are Internet Explorer, Firefox, and Chrome. I'll list the steps for each.
Internet Explorer:
  2. Click Tools, and or click Internet options.
Under the General tab, enter the web address of your new home page, and then click Apply.
Firefox:
  1. Open the web site you want to set as your home page. If you want a blank home page, open a new tab.
Chrome:
  2. Select Settings.
    • Set your homepage
      When the "Show Home button" checkbox is selected, a web address appears below it. If you want the Homepage button to open up a different webpage, click Change to enter a link.
Feb 15, 2013 | Computers & Internet
Hi there, First of all I'm completely new to GPS and a friend gave me her Garmin 255W, I've managed to fine a USB cable which charged this unit which is a plus but when I go to checking out different...
You can clear all the user data by holding your finger on the bottom right corner of the screen when turning on the satnav. Once the data is deleted you can set your home location by pressing WHERE TO and then GO HOME. As you won't have a home destination set it will give you 3 options
  1. Enter your address
  2. Use current address
  3. Choose from a list of recently found locations.
If you're at home, choosing option 2 is probably the easiest. You'll need to be outside so the satnav can access satellites. If you're not at home you can use option 1 or 3.
You can find the user manual for this satnav at http://static.garmincdn.com/pumac/2675_OwnersManual.pdf
Apr 05, 2011 | Garmin nuvi 255W GPS Receiver
I've log in facebook home page, but there is a msg pop out asking me to complete a survey if not I can't go further to use the facebook. Pls help!!!
That normally happens when you are using a different location to log into Facebook, or if you are using a wifi connection in a location that is not your home as it will create a Differnt IP address each time. But you MUST answer all the question correctly, if you are not sure off the picture click on that option as if you get a question wrong it just keeps asking you time and time again
Jan 15, 2011 | Dell Inspiron N4010 Notebook
My navigation system in my 07 camry keeps telling me the address doesn't exist when I know it does. It won't find any address
If your GPS is not finding any address, then the most likely cause is that the wrong country map is loaded or the map is corrupted as finding an address does not rely on getting any satellite signals (your GPS should at least show your home location or the last known position on the 'correct' map): I suggest that you look at your specific GPS user manual to find how to check that you have the correct map loaded: if it is the case, then find the instruction on how to 'reset' your GPS as its software may be corrupted.
Hope it helps.
Jul 15, 2010 | 2007 Toyota Camry
Reset home address from guam to united states
Click preferences, manage maps, then switch maps. Switch is to USA/Canada and you'll be all set!
Dec 31, 2007 | Tomtom GO 510 GPS Receiver
Tomtom ONE XL GPS Logo
112 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
