The cooker clock lost its memory during a power cut. At the moment the clock registers 00.00 auto It should register 12.00 auto to be able to fix the clock.
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Nice Australian cooker but an unknown make to us here in North America.
Clocks always flash when you cut the power to inform you that the clock is incorrect. Perhaps you had a power cut in the night. If you have tried to set the time and can't, you may have a sticky button.
First I would say to unplug it wait a couple seconds and plug it back in case it got a power surge from the power going . Then reset the clock! Right now it's set in a power saving mode until you do the steps above!
If your clock is flashing 12:00 then do this: Touch the + or - buttons whilst the display is flashing to adjust the time. The display stops flashing after 5 seconds and time is displayed. To adjust clock time : press mode button 4 times until clock symbol is displayed. Use + or - buttons to adjust time.
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
I am assuming you have a touch pad for the clock. You can hold down the time button for a few seconds an it should start blinking. If it doesn't work, try pushing the "set" button for a few seconds. Usually, you can find it by trying all of the buttons til you get the right one. Then, you can adjust the time by moving the up and down arrows.
