Hello I'm european and would like to know what is the voltage in watt, of the Lasonic Ghetto Blaster i931 Boombox ? also, can it be adapted to the european 220 v ? or do I need a transformer.I know that it can works on batteries, but I'm sure that it must consume a lot !!! too much probably !!!
thanks for your answer
Marie
SOURCE: brand new lasonic i931 boombox wont turn on!!!
okay, i had a similar problem, and the problem turned out to be a bad connection. If you open up the battery box, in the bottom top left corner there is a positive connection wire that looks kind of like a "U".
this connection doesn't come in contact with the batteries, so you need to extend it by wrapping a small piece of wire or something to make it stick out more.
what we actually did was put a piece of 1/4 in. by 1 in. piece of copper flashing in the plastic slot and across the U shaped connector to increase conductivity and it works fine.
i hope this was helpful!
SOURCE: My lasonic ghetto blaster won't come on
Happened to me. wasn't the U shaped connector. It was the connector on the right hand side, it gets pushed down over time. If you look at it and you see that its not pushed all the way up, then thats the problem. I opened my box up and physically pushed it up. It slides right up and then close it back.
