Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Mar 12, 2010
Anonymous
Expert
Level 2:
Answers
77
Questions
Helped
13876
Points
171
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Windows media center can not find ir receiver
be sure you have installed the driver. If you are using windows 7 you still need to install the winTV driver. I know this because I had the same problem. It should work then. Just go to TV setting in the media center setup and it should scan for channels.
Digital Transition
It's analog.  You need to purchase a digital receiver.  I personally have a USB external digital tuner running in Media Center 2005.  Search Ebay for "ATSC usb".  There's a lot of different options and most of them are pretty inexpensive.  To use a digital tuner in Media Center 2005, you have to leave the analog tuner / tuners in also.  You should still be able to use your current remote control with the new digital tuner.
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
2answers
TV Tuner for my HP
Hello Matt,
WISH YOU HAPPY MERRY CHIRSTMAS!!!!!!!!
I am Vikram Kumar Thumu from India- Hyderabad. I have seen your message on the issue related to the Tv Tuner card. Since, I work with HP as Technical Support I would like to suggest you on this issue.
Well, the "HP ExpressCard TV Tuner for Windows Vista
(RM436AA#ABA)" supports only for Windows Vista.... and it will not work with Windows XP.
If you are lookng for Windows XP Tv Tuner Card, I recommend you to purchase Hauppauge WinTV-PVR USB2 (EC557AA#ABA). As this one supports for Windows XP but needs Microsoft Windows XP Media Center Edition 2005 .
These are available solution for you at this moment . I hope that this should resolve the issue for you.
If you need any other information please do mail me at [email protected]. I'll be glad to help you.
Once again WISH YOU HAPPY MERRY CHRISTMAS!!!!!!!!!!
Thanks,
Bye...
Top Hauppauge Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
