HP Deskjet D2360 InkJet Printer Logo
Posted on Jan 06, 2010
Don't want to start
My dad wanted to print something on the printer and clicked a lot of time on the print button, but he got irritated and pulled out the cable from the computer after a while. Then when it didn't want to tur off he pulld out the cable with electricity and after that the printer doesn't want to start or nothing!!! No lamps are blinking or anything!
Please help me!!!
5 Related Answers
A
Anonymous
  • Posted on Feb 08, 2008
SOURCE: printer won't print
I've had this 6110xi all-in-one for a few years now. Everytime I have the "no-printing" issue I need to unplug the printer, and leave it unplugged overnight. The problem magically goes away in the morning.
I've installed the printer on a separate computer while it was having a "no-printing" episode and still couldn't print there either. So it sounds like there's something funky with the printer internal cache requiring a long power-down.
Anonymous
  • 44 Answers
  • Posted on Nov 16, 2008
SOURCE: ''clicking'' noise started randomly- cant use printer
Hi starrz54,
Here is the HP site that talks about resolving unexpected noises (such as clicking)...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06191&lc=en&dlc=en&cc=us&lang=en&rule=26695&product=303753
You also might try doing a full reset on the device. Here is how to do that: While switching on the scanner press # and 9 to initialize.
I
This should give you some good directions and if it does not resolve the issue, the next step would be to have it serviced or replaced.
Anonymous
  • Posted on Apr 01, 2009
SOURCE: my HP laserjet P1006 won't print
free driver download
Anonymous
  • Posted on Apr 26, 2009
SOURCE: lower light blinks on everytime I try to print anything and nothing prints
tried new artridge and no paper blocked yet still flashing
Anonymous
  • 3 Answers
  • Posted on May 13, 2009
SOURCE: 3940 blinks and cant pritn
hello lotsaprint, ipang
Few days ago i had the same problem with my hp 3920 color photo printer. All i did is removed the cartridges one by one and the problem was solved. Try removing the color cartridge first, then switch on the printer see i the problem is solved the cartridge contacts must be dirty. clean it with soft tissue (dont use any liquid) and reinsert the cartridge. If the problem persists u may need to replace the cartridge. Check with a new one if u can borrow one from anyone b4 u buy.
Repeat the same procedure with black cartridge if necessary. If u r new and need guidance for removing the cartridge, then do the following.
1). Switch on the printer.
2). Open the front cover. The cartridge will now move to the
center.
3). Switch off the printer and remove the power cord.
4). push the cartridge gently downwards to detach.
Close the cover when u r done with above mentioned.
For more info see the user guide u go with the printer.
Hope this was helpful
anishpillai2
Cant find instructions to print off how to use in English
Using a printer even basic printer is extremely easy to do. There are many different models of printers out there. You have your very basic to your all-in-one printer. The printer with everything on it works pretty much just like the regular printer you just have a lot more buttons to push.
Make sure that your printer is hooked up properly before using it. If this is a brand new printer then it will go through a check and print out a test page for you. A lot of different times you can just turn it on, you will hear the ink moving around. Something might come up on the computer telling you that the printer is on and working properly.
Open the page you want to print. If you are on the Internet and want to print something from there. All you have to do is go up to file, then down to page set up. This will give you more printing options to choose from. When you are done setting up the page you can verify you have the right printer hooked up by clicking on "Printer" at the bottom. Once everything looks good click on "OK" and now your page should print out.
Open up a ".doc" file if that is where your page is that you need to print. When you are ready to print go up to "File" and "Print Setup". Again you can choose how you want your page to look, and check and make sure the right printer is installed. If your page is set up the way you like it you can just click on the printer icon on the tool bar or go to "File" then "Print."
Using a printer a lot over time will start to wear down your ink supply. Some models of printers let you know when your ink supply is getting low. If you have an older printer you will just have to go by what the printed page looks like. If it is very worn and faded then it is time to install a new ink cartridge.Go to this site www.knox.edu.com and www.openprinting.org
Spools will not turn
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
I have a brother mfc 490cw. I have only printed from microsoft word. But whenever I print a page it runs another page reporting the file name, directory,template title, subject, author, keyword, comments...
Hi there!
The issue that you are having is because of the settings on your Microsoft Word. Here's what you can do to resolve the issue.
  1. Open the document you want to print on Microsoft Word. Click on the Orb icon on the upper left hand corner which is also called the Office button.
  2. Click on Print and click on Print again. The Print window should be open by now.
  3. On the lower left hand corner of the print window you will see the options button. Click on the Options button. You should now have the Word Options window.
  4. On the Word Options window. Click Display from the Left panel, you should see Printing Options.
  5. Make sure that under Printing Options only Print Drawings created in Word is Checked and leave the others unchecked. Click OK. Click OK again. This should print your document without the other page.
Hope this helps! Have a Good day!
My printer is hooked to my laptop but when I click on something to print it will not print anything.
Are you able to make copy standalone ?
If yes, follow the steps on your pc
Click on start button
Click on Control panel
Open Printers and Faxes Folder
Check if there is any documents stuck in Queue on the printer icon
If yes, Right click on the icon and click Cancel all documents, ( do it 2-3 times )
Refresh the page by pressing F5 button on keyboard.
Disconnect the printer power cord, Restart your PC and connect the cord.
Try to print
Regards,
Ron
I have lost instruction leaflet and do not know how to operate printer
1. Using a printer even basic printer is extremely easy to do. There are many different models of printers out there. You have your very basic to your all-in-one printer. The printer with everything on it works pretty much just like the regular printer you just have a lot more buttons to push.
2. Make sure that your printer is hooked up properly before using it. If this is a brand new printer then it will go through a check and print out a test page for you. A lot of different times you can just turn it on, you will hear the ink moving around. Something might come up on the computer telling you that the printer is on and working properly.
3. Open the page you want to print. If you are on the Internet and want to print something from there. All you have to do is go up to file, then down to page set up. This will give you more printing options to choose from. When you are done setting up the page you can verify you have the right printer hooked up by clicking on "Printer" at the bottom. Once everything looks good click on "OK" and now your page should print out.
4. Open up a ".doc" file if that is where your page is that you need to print. When you are ready to print go up to "File" and "Print Setup". Again you can choose how you want your page to look, and check and make sure the right printer is installed. If your page is set up the way you like it you can just click on the printer icon on the tool bar or go to "File" then "Print."
5. Using a printer a lot over time will start to wear down your ink supply. Some models of printers let you know when your ink supply is getting low. If you have an older printer you will just have to go by what the printed page looks like. If it is very worn and faded then it is time to install a new ink cartridge.
Printer Help
I replace my Black ink with new and it will print only a few times then the black streaks and then stops working. I clean the heads and it don,t help. Change to another new black ...same thing print a few...
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
1helpful
Hi, I have a sumsung ML 2510 printer. It was very good until recently it prints paper with lots of black line mark on each page. How can I fix that problem? Thanks. Margaret
The printer don work and it shows has no ink,but das have ink
2helpful
Cancel printing doesn't work
If you have tried a reboot then why don't you try a Soppler Refresh.
Click on Start> Run (and type Services.msc) Hot ok.
It should open services window up.
Then look for Print spooler> Double click on it> Under General amke sure startup type is selected as Automatic> Then down you shoul see a tab which says stop> Click Stop (Now a small windows popps up and closes) You will see Start Highlighted> Click start and stop will be higlighted> if applicable click on apply or ok and close all the windows and restart the computer.
Then go to Start> Control panel> Printers and faxes> and check to see if the icon say 0Ready> if yes right click on the icon and left lick on Properties and then in the bottom you will see a tab which says print test page> click and see if it prints a test page.
Then try printing any document.
Good Luck
HP 7450 printer doe snot start printing
this can be caused by power glitches blowing the drivers out. I'd connect the printer to it's own power strip, and then directly into the wall outlet. Do NOT plug any modems or wireless devices into the same power strip. Got backup?
k24674
Grand Canyon Tech
Grand Canyon Tech
