Hi I am trying to repair the electrics on the drivers seat on a C class mercedes (2003). None of the motors are running. The passenger side is working correctly. I have checked as many fuses as I can but do not have a list of all the fuses and what they do or a wiring diagram. The power plug on the drivers side has 3 wires in it one has 12V on it. On the passenger side two have 12V on them. Is there a fuse box diagram or wiring diagram that will help me find out what has gone wrong (I have checked the handbook).
SOURCE: mercedes a class gear box problem
if there is 'F' apearing on d dashboard. most probably its d FTC problem. go on com.diognosis n check d fault..
SOURCE: mercedes c class c180 2001
hi,rear sam control ,fuel gauge,tail light,depends what equipment install at the rear,ty
SOURCE: have mercedes E class key fob will not open doors,
If key will not turn
Car battery flat,charge or jump to activate elec ignition
SOURCE: mercedes 2001 c class driver seat adjustment not
In 2001 two c class
models 202 and 203
202 check fuse box in boot,spare wheel area
Fuses 12/13 25amp,these both control drivers seat
203 later c class
Check fuse box in boot, fuse 2 30amp,also fuse 38 30amp,located in fuse box end of dash
Testimonial: "THANKS"
SOURCE: how do i adjust the analogue clock on a e class
set the digital one and press R button and hold for 3 second on instrument cluster for confirmed then wait one minute and keep eyes on analog clock you can see it's adjusting itself wait until reset the time and switch ignition is this information helped you?
