Bosch Classixx WFL 2066 Front Load Washer Logo
Anonymous Posted on Jan 06, 2010
Key symbol showing
How to unlock child lock on bosch classixx 6 1400 express washing machine
prem mathew
Level 3:
  • Bosch Master 662 Answers
  • Posted on Jun 14, 2010
prem mathew
Bosch Master
Level 3:
Answers
662
Questions
Helped
265218
Points
1748
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
I have accidentally put the child lock on my washing machine but have mislaid my instruction manual. Please help.
A re-posting of a Fixya answer:
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
How to unlock a Bosch classic 6 1400 express washing machine ?
The key symbol indicates child lock has been set.
Press and hold the start button until the key symbol goes out.
You should then be able to use the appliance.
13helpful
2answers
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
9helpful
Bosch classixx 6 1200 express is showing a key symbol in the LED - when I switch on the washing time goes back to 0 and the alert sounds and I cant start the wash I dont know how to switch the key...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
91helpful
2answers
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
25helpful
When I select a cycle the -0- is displayed and the lock symbol.
YOU PROBABLY HAVE THE CHILD LOCK ACTIVATED GENERALLY HOLDING THE LOCK BUTTON IF THERE IS ONE OR THE START BUTTON FOR 5 SECS OR MORE WILL TURN IT OFF ALLOWING NORMAL USE
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
