Televison & Video Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Samsung 46in tv with no manual and can not tune in a channel for dvd and its telling me that there is no manual available
Anonymous
Level 3:
  • Master 556 Answers
  • Posted on Jan 06, 2010
Anonymous
Master
Level 3:
Answers
556
Questions
0
Helped
154122
Points
1096
Most dvd players go in audio video input not on a channel, you have to change the source. It is usually hooked up with a yellow, red, and white rca plug.
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Have older tv, cable ready only. Hooked dvr to it...cable in dvr then to tv, but cant get setup to come in on any station. Tried both E1 & E2, get nothing
You will need to manually tune a new program channel in to the frequency that the DVD outputs at. It will tell you the frequency it is in the DVD manual. It will be Analogue TV rather than Digital TV option on TV so you need to tune in an analogue channel manually. Also make sure you use an antenna cable at 75 ohms impedance rather than a video cable. They look exactly the same but electronically they are quite different and a video cable will not work from RF out DVD player to RF Antenna In on TV.
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
How do i hook up my rca dvd to my samsung tv its hooked up right but i can'y figure out how to get the tv on the right channel for it to work
This DVD player only has audio and video outputs. You'll need to connect it through one of your TV's A/V inputs, then switch to that input to see the DVD signal.
If your TV doesn't have A/V inputs available, you'll need to connect the DVD player using an RF converter. This takes the audio and video signals from the DVD and produces a channel 3 or 4 output you tune in on your TV. Converters cost around $10 to $20 and are available at Radio Shack or retailers who sell TV's.
Ndt-40 manual
Stick a dvd or video in, press play, then auto/manually tune your new tv. Or simply plug in to AV slot if available.
LN-R460D 46in, channels intermingled
are you using digital or terrestrial transmission? try fine tuning it...and hey, check the antenna direction, and also the wires...if the sockets are tight enuf and are correctly connected.
2answers
Tuning a samsung tv to a phillips dvd, a goodmans video and an akura freeview box
It sounds like you are trying to tune in the dvd and video to a free channel on your tv, I would suggest using the scart connection if your tv has one. Scart leads only fit in the one way so you cant go wrong. Scart leads are available everywhere including tesco.
Once the scart leadt isconnection between the dvd and the tv then use the AV1 button on your remote controll and you will get sound and picture in better quality than manual tuning.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
