SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
SOURCE: resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
SOURCE: dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
SOURCE: i have a dkny watch
it doesn't have arrows because you have to use small screw drivers to loosen it. so you can adjust it. You can buy it on any hardware store. i hope i had been helped you.
