Hello! I have a 1 1/2yr old whirlpool mh3184xp microwave hood that stoped working for no apparent reason. It was not in use at the time, other than the lo hood light being on which we leave on at night some times. I was in the kitchen at time it lost power. I herd a click or a small popping sound and then the light and all power to the microwave was out. I unplugged the microwave, check the breaker, check the outlet for 120 power, plugged in three diffrent appliances into same outlet an they all worked fine. plugged the microwave back in an still no power. I would greatly appreciate if you or someone who has resolved this problem can help me.
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Unscrew the unit replace fuses trere are 2 fuse in the microwave 1 in ac input 2nd in the high voltage transformer replace the one in the near the transformer its,.replace it
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Same model same age same problem.
I have the same exact problem. These things are bAd.
How do I get to the fuse by the transformer? Do I have to take the whole thing down??? errrr
