RTO Automatic Transmission And Engine Oil Pressure Tester Logo
Zip Rowlands Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for a service manual.zf 260 transmion
Anonymous
Level 2:
Scholar:
  • Expert 172 Answers
  • Posted on Jan 06, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
172
Questions
0
Helped
100544
Points
362
It looks as though you can order them through zf.com.
2000 Audi a 8 quattro transmission code.. Said short circuit to valve solenoid b+
all cars worked before and not one ever lasted 22 years and not failed
unless put intro a HUGE NASA VACUUM CHAMBER FOR 22 YEARS.
SO LETS FOCUS ON A PROBLEM 1 AT A TIME. i BET MORE.
doing swaps like that can make it worse for the fact that they are not all the same Audi Part (number)
in fact makes it worse.
the car has real transmission name and even a manual for car and the maker of the box has one too.
your scan tool dead
1: check all fuses for sure to TCM
2: scan the PCM, in USA we use obd2, scan tools 1996 up.
you did and fail to tell the DTC code above, why do that?
DTC codes must match the box, not told
AWD OPTION?
2.8 V6 model and the long-wheelbase and short-wheelbase 4.2-litre quattro.
VAST VERSION EXISTS. 4.2L is common USA <<< bingo I think
so lets find what tranny is behind this engine
only evidence is "slipping out of know where" yes alled FLARE or false neutrals in drive, (lots of cases but sure solenoids.)
slips in 1st gear or a 1>2, 2>3 or 3>4 shift points. RPM/Speed.
there are 8 devices on the valve body not counting thermal sensors
that look like shift solenoids but are not.
the german's use odd names for parts as seen here clearly
n88 n90 do all shifing
but N215 to 233 are no the same. at all.
mixing parts up is bad trouble.
the BOX maker and real name is here
FITS ZF-5HP24A (01L) EQUIPPED AUDI: ZF IS MAKER.
created by the German ZF Friedrichshafen AG engineering company.<< BINGO?
knowing just this one fact makes learning what part numberS all 8 are.
sonnax says
https://www.sonnax.com/tech_resources/348-zf5hp24-solenoid-identification
MV1,2,3 same (Shift sols)
ESD1 IS FULLY UNIQUE
AND ESD2 TO 5 ARE SAME.
SO THE 3 SETS CAN NEVER BE MIXED, AS I SAID.
THE SERVICE MANUAL COVERS THIS FROM ZF MAKER.
USA SM, 4.2L box only shows this A8
german-ugh-undefined-undefined-0.jpg THE FOR COST MANUAL IS HERE
FREE ONES ARE OUT THERE BUT I DO NOT GOOGLE FOR DAYS
24A IS IT NOT 24-(NULL)
https://www.ctpowertrain.com/zf5hp24a-audi-awd-oem-zf-repair-manual-guide-book-1997-on-5hp24a-5-hp24a-5hp24-a/
OR FLEA BAY
https://www.ebay.com/sch/i.html?_from=R40&_nkw=ZF5HP24A%2C+MANUAL&_sacat=0&LH_TitleDesc=0&LH_PrefLoc=2&_sop=15
google luck
PS:
most modern boxes run a modulated pressure (main line) control
solenoid, PCS, if bad it can not upshift or is late or flares.
ZF does it all their way. (I know GM/jeep) so...
How do I remove sir clip from main shaft for a ford tw25 ZF front axle
you can get help from the service and repair manual with diagram and you can get the manual from the given link http://toolsnyou.com/
2helpful
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
1helpful
6.5Lchev diesel to a ford ZF 5 speed gear box
You will need the Chev pressure plate to suit the Chev flywheel and a clutch plate to suit the Ford ZF gearbox. Ford ZF throwout bearing and clutch fork should be fine.
Not cooling and building ice on the refrigerator side
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill i'm sure that the defrost heater is not working......................have a nice day :-)
Top RTO Measuring Tools & Sensors Experts
Arleth White
Level 1 Expert
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
