This unit is 4 years old. All maintenance performed yearly. This year, no water from solenoid. The humidstat is a '56'. Won't work in 'test' position.
Outside sensor is hooked up to humidistat:
The following voltage checks were performed:( while on and demanding heat):
- voltage from transformer to humidistat = 27 volts
- voltage from humidistat to solenoid = 13 volts.
I am assuming that the humidistat is faulty, would this be correct? Would appreciate any guidance on this problem. Thank you
tc
It sounds like you got it...
The solenoid will not open with only 13 volts to it. Jump or apply the full 24-27 volts to the solenoid and see if it clicks and opens and allows water to flow.
If the valve still won't open or pass water, start looking for a plugged inlet solenoid inlet screen or a faulty solenoid valve as well as a faulty humidistat.
Testimonial: "very helpful, thank you"
To perform the solenoid 'jump' test, I'll disconnect the red and white wires from the humidistat to solenoid and jump them to the two posts that show the 27 volts from the furnace which I presume is from a transformer. Would this be correct? And, if all works properly from this point, why not just leave it, and forget about the humidistat?
