Shelf stereo turns off by itself and stops working all together.
I have a philips fw93 shelf stereo system and it tends to shut off with out waring at random times. it doesn't come back online unless i unplug it for a few minutes then replug it. the cd player also stop playing but yet you can her the disc still spinning.
Re: shelf stereo turns off by itself and stops working...
How loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer Ā· CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Are these speakers compatible or are you just adding speakers because you have them hanging around?
If you have effectively less than 6 ohms of impedance on any channel you may run into problems and the unit may either die or protect itself by refusing to stay ON.
It's fairly obvious that if you do X and undesired Y happens you might want to UNdo X and rethink it.
You cannot . This a feature that detects a short and shuts the stereo off before it can do further damage. If you can disconnect your speakers try that then turn on your stereo. If it displays protect mode your problem is internal. If it stays on try hooking up one speaker at a time to see if one of your speaker is bad. Make sure you turn off your stereo before attempting to reconnect your speakers . Good luck
To stop the demonstration mode
• Press and hold stop (on the system
only) for five seconds when the
system is in demonstration mode.
ª The demonstration will stop.
ª "DEMO OFF" is displayed.
ª The system will switch to standby
mode.
