Wacom Intuos3 6X8 USB with Pen&Mouse [ PTZ630 ] (127137) Logo
Posted on Jan 05, 2010
"Insecure Startup Item Disabled" What do I Do?
I install the drivers and plug in the tablet when i go to configure it in system preferences it tells me that no tablet is detected even though i can use the tablet as a mouse. It tells me to restart the computer and reinstall the drivers, i do so so and when i reboot the computer and sign in a message pops up that reads:
"/Library/Startup/Tablet" has not been started because it does not have the proper security settings.
I need to get this tablet working soon so any help wpuld be much appreciated.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2318
Points
Did you find the solution to this yet? I have the exact same problem with my Wacom tablet.
  • Anonymous Mar 30, 2012
    I have the same problem, please help
2answers
Fn key do not work like volume brightness and video out
uninstall the acpci driver from the add/remove then reinstall
1helpful
2answers
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
1helpful
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
2answers
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
1helpful
3answers
Intuos3 and Mac OS X (10.6)- No preferences menu/program/software
hello, just go on the wacom site and download the newest drive for mac os x, i was having similar problems, but now everything's fixed and it's working fine!
go to the following link,
http://www.wacom.com/downloads/driver-detail.php?id=215
2answers
3helpful
3answers
The computer is not recognizing the Linksys wireless card. When the card gets plugged in, it lights up like usual, but now the computer is not recognizing it at all. It used to appear in the bottom right...
look out for the driver of the wireless card. check the system configuration were you have all installed hardwares and see if you can find thr card there. if it is not there, then you may have to get the driver cd and re install it. other wise uninstall the driver and re install it again. but first, go to network connections and see if it is there or if it has been disabled. if it is disabled, enable it and you will be fine
DigiPro WP8060 Configuration Utility Not in System Tray
I have the same tablet, and it's because your using the wrong driver. The driver you need came on the CD with the tablet, and you can google around for a bit to find the proper driver installer from DigiPro.
Windows has a generic tablet driver that will usually install for almost any tablet, however, it only enables the tablet to be used as the mouse and does not support configuring tablet features or using pressure sensitivity.
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Top Wacom Computers & Internet Experts
k24674
Sean Wright
Sean Wright
 Grubhead
Grubhead
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
