Hi,while skyping my web cam doesnt work.I tried opening the programme to adjust setting,but that wont open either.what can i do?thanks Denis
How do i updade webcam without disc?
I followed this pattern - Control Panel, System and Maintenence, System, Device Manager.
Once you get to this page you should see an alert symbol next to the Acer Crystal Eye Webcam, under the Imaging devices tab.
If you double click on the warning it should bring up another sub-window giving details of the webcam. Then click on the drvier tab at the top and click Update Driver. I clicked on automatically update and it worked straight away after that!
Hope this helps!
I have a note book of ACER ASPIRE 5920-6864 the camera crystal eye is not working please anybody cud help me
Dear gentlemen,
Please update the driver if necessary at Control Panel, System, Device Manager, Imaging Devices/Human Interface devices, Insert the CD driver click update at top menu level and browse for it. You can also check at the manufacturer's website for any updates. Since this problem occurs in different manner or complex due to other system faults, please scan viruses and spysweepers. Free AVG is good enough and demo version of Spysweeper is fine enough to check and guard for a month. Hope this helps.
Best regards,
Rosener Guyano
Acer crystal eye webcam error is found in my acer 5745 aspire series....... no video capture device is found
There is a crystal eye patch availible, Acer will send it to u if u call them.
Pleas help my prb ıs same but ıt cant solved with your suggest gıve new answers
Vssd
Read this thread...
My acer crystal eye webcam is not working - Microsoft
How to webcamera key in laptop. I don't know. when the key switch in laptop. Ok Thank You Take Your Self
I get this message everytime i try to use the webcam with msn messenger: Kan ikke starte kameraenheten. Kontroller at kameraet ikke brukes av et annet program, og prøv deretter på nytt.
uhm, that was in norwegian, i'll try translating it as good as i can:
Can't launch the webcam. Please make sure the camera rn't being used by another program, then try again.
i have no idea what do do :(
Any suggestions?
pls feel free to send me an e-mail if u have any idea or hints of what might solve my problem :) [email protected]
People I have the same problem, my suggestion buy a mini webcam. You canfind them on ebay, Walmart or Walgreens for $20 or less.
My laptop screen smashed. i went to get my laptop screen repaired. the webcam is still there and i can see it everythin else is still on my laptop but my webcam does not seem to work ..
i tried delete it then.restoy it
I click on my acer webcam icon to take some stills and microsoft windows pops up and says i can run this program want to search web for problem i hit yes and it doesn't find a prob.
the webcam works fine with my trillian application but i'm trying to get a still.
Hi,while skyping my web cam doesnt work.I tried opening the programme to adjust setting,but that wont open either.what can i do?thanks Theodore
camera is not working
my crystal eye does not work.I CANT FIND THE PROGRAM!!
i can use it only off line and when i am on line it is only black window in place where should be broadcasting
I can't open the webacm for some reason. Every time I try the message, "Acer Crystal Eye webcam Application has stopped working"
- "A problem has led to the program not working as it should. The program will be closed, and you will receive a message when a solution is available"
acer aspire
i can open up my acer webcam but it will only take pictures i can't figure out how to use the webcam. i can't adjust the brightness or anything.
first i open my web cam , i see a ballon on my desktop saying "this device can perform faster" and something like that concerning the "port Hub"
Simplemente no funciona. Acer aspire 5920. Cuando se configura el computador, el programa no la instala. Lo he intentado varias veces y es el mismo resultado,no funciona. No tiene sentido cambiar de computador con camara incluida, si a la fine uno queda con un equipo peor que antes.
Webcam was working on my Acer One, but now system says camera cannot be found. DSoesn't show in My computer. Add camera in control panel does not find camera driver of that brand. Tried reinstall drivers in acer empower ctechnology feature - but no use.
I was using my webcam and all of a sudden it said that it was deleting the file, i dont know how i deleted it and i cant find the programm anywhere, not even in my trash can. ???
When ever i try to go on webcam on via msn it doesnt work and it hasn't worked for a week now.
Whenever i try and use my webcam with via msn it doesn't work.
when on msn chat when trying to start up the webcam it says it can not start, i need to check its not being used by another programme and try again. Its not being used by anthoer programme that i know, but did only get the laptop about a week ago
hi i have a aspire 5535 the cam works however the control options are not available , i have not got any CD to update driver and i have don it on line but its telling me its updated/
really confusing :o) thanks
the web cam is not working
when i run my web cam it shows camra not found......
my laptop.. (Acer aspire 5535) is working fine and so is the webcam and i have had no problems.. how do i make videos though..xx
My webcam is not working. I can not find the program on the computer.
my webcam does not work with msn messanger or yahoo messanger. i have updated the driver stil not workin. what to do now?
I have an acer laptop model aspire 5920 and my webcam is not working. when I looking in the files tells me that is not installed. what can I do?
i cant open my wbcam.
if i wont open it it is said "web cam not found"
when i turn on the cam it appears dark everytime
my crystal eye webcam not working
My webcam got completely erased from my Acer. I try to download another but it wont work
i dowload and install acer eye crystal webcam from the internet. but every time i open acer eye crystal webcam a message appeared CAMERA NO FOUND
WHAT should i do?
even my bluetooth and wifi ..every time i pressed the fn and f3 nothings appear.
i cant get on skype i cant turn my web cam on tried all the normal solutions going into control panel etc
DO NOT DIAL/CALL 4187 PHONE.
DANGER AWAITS YOU.
