I've downloaded games,put them onto my micro sd card, put that in my r4 card, put that in my DS but its not working. When I put my r4 card into my ds the bottom screen is blank white and the top screen says MENU? in red with a red box around it. Please can you help???
First make sure you have the correct kernel for the card. Go to the website where you purchased it and download the current firmware. Next copy all of that onto the micro sd card. Build folders in you sd card, very simple right click...new folder... enter... then label them correctly .. Label one movies... music... games.. etc... then put your files into the correct folders.. Another common error is that people use to high of a sd card.... some r4 cards only accept up to a 2gb micro card If you use one that is too big it will stick on the loading screen ... If none of this works reload all the software onto the card and start from scratch... hope this helps
SOURCE: accidently deleted my nintendo ds r4 menu now i cant play help help HELP
i can e-mail you the _system_ folder and the .DAT files. i won't spam, i'm not that type of person. i'll delete your e-mail address after. i promise.
reply-e-mail address.
SOURCE: R4 cart not loading
instead of copying and paste send the files to the micro sd thats what i do no problems at all
SOURCE: Putting the Micro SD card and R4 on Nintendo DS
had the same problem if you can get an r4 card you no works copy entire contents over to your card then delete ther games and add yours but keep there kernal . dont forget to format your card b4 copying ther card
