First, it's not booting from a CD or Hard Disk if you've reached that error. The 'last-ditch' effort to boot is to attempt a PXE boot from the network card, but your Ethernet cable isn't plugged in. Unless you know you've setup such a PXE boot server, you'll want to check the BIOS settings to be sure the CD-ROM is set to boot first, followed by the Hard Disc. Be sure you have Disc 1 of the Linux installation set in the CD-ROM Drive and reboot. If you don't get the install screen, you may have another issue (bad CD-ROM Drive, bad cable/controller, no power to CD-ROM, etc.)
Another note on the DL380, if there is a RAID controller, you'll need to setup the RAID before installing the OS. You'll want to make sure your hard drives are properly installed and aren't failed. The RAID configuration screen will verify the RAID status once it has been initialized, which will somewhat verify the drive status.
Can you hear the drive spinning? If not, then you may want to check the power supply. You can also try different ports and cables, or try it on another computer. Another possibility is that the directory is damaged, and DiskWarrior can often repair the directory and allow the drive to mount.
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Sounds like one of two errors - either one of the power supplies has died (not sure if the 1800 has redundant power supplies or not) or a drive in the RAID array has failed. Most likely it's the drive. Run the Dell Server Administrator tool to check the health status of the array, sounds like you need to replace a drive. Most RAID systems fail if you lose more than one drive, so I'd replace that drive ASAP.
It sounds like this drive is configured with two drives running RAID 1 (mirroring). If one of the drives inside the case has been removed or has failed, it needs to be replaced with an identical drive so it can resume mirroring.
Raid 1 requires two had drives. Both drives are kept absolutely identical so that if one fails, the other continues to serve your files, but you will get a message like the one you have reported to let you know that a drive is missing or has failed.
If you look in the case and there is only one drive, but a place for a second, then someone has removed the drive.
If you look in the case and there are two drives, then the drive identified as Drive B has failed or has become disconnected, try re-seating the drive and check any cables or power connections. If it begins to work then, you may have solved the problem, otherwise you will need to get an identical drive and put it into the case. The raid controller will automatically identify that a new drive has been installed, then it will partition and format that drive automatically and resume the mirroring process.
I would try the hard drive on another sata controller/port to verify that the bad drive is in fact bad. If it is really bad, then no there is nothing you can do but replace the drive and recreate the array (losing all data!).
You can not 'recover' a failed RAID-0 array because there is no parity or mirror data on an extra disk like there is with the other RAID modes. This is why people recommend against using RAID-0 for important data (unless you take frequent backups): RAID-0 actually increases your likelihood of losing your data. Statistically speaking, you are multiply the failure rates of each individual drive together.
the scsi and raid refers to sata hard drives or ide in a raid configuration.
the dvd drive if on a cable on its own should be set at master, if on a cable with another drive then set it at slave, cable select doesnt always work as the motherboard cannot identify the ide source.
Youe DVD drive will be listed in device manager under cd/dvd drives, click the + sign and if it's listed there, right click it and select uninstall.
Restart the pc and see if it's reinstalled automatically, it should do, then be ready for use, if you still cannot see it in my computer check the drives ide cable and swap the drives over if necassary, if still not showing the drive needs to be replaced.
