Question about Kirby Ultimate G Bagged Upright Vacuum
Shampo system I have checked the filter. still getting lots of water and no suds. help.
    Sniper:
  • 112 Answers
Here is a site that has detailed instructions for using your kirby shampooer.
the screen that goes in the hose is different from the filter (round flat sponge) that goes between the exhaust side of the kirby and the shampooer tank. The screen is what makes the suds...if its not seated properly or missing (or damaged) then it won't make suds.
http://www.greatvacs.com/shampoo.shtml
this site shows a picture of the piece I'm describing...its the 3rd picture down, called the gauze filter...still its different from the sponge filter....
also...make sure you go slowly with the kirby (and lower it to its lowest setting) if your carpet is heavily soiled....the enzymes in the shampoo are what clean the carpet (oils, grime, etc) and if its heavily soiled the suds disappear almost immediately.
Hope this helps!!!
Posted on Feb 05, 2008
SOURCE:
Bissell 9500 ProHeat, Why is it leaking water from the dry air vent?
The only thing I have seen cause anything like this is a high suds level in the waste water container. Usually caused by using pre cleaners on spots on the fabric. Those pr-ecleaners, i.e. Resolve, etc. create a LOT of excess suds in the waste water that can be sucked up in places they shouldn't be.
Jul 06, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
What type of store baught shampo will work best to shampo with kirby g dimond
The Kirby G Dimond edition needs to use the genuine Kirby shampoo solution below:
Kirby Allergy Control Shampoo - 32 Oz. Kirby Part # 252702 - Free Shipping
Also available in a gallon size.
Apr 15, 2010 | Vacuums
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
May 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Shampoo does not sud
The suds screen is not there or is somewhere in hose elbow. Click HERE and read the tip about installing the suds screen.
If you want to see where the screen is supposed to be installed - see out Kirby shampooer manual HERE.
Good Luck
Rocky
Apr 03, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby shampooer dispensing - NOT a filter problem
I had the same problem and I called my local Kirby guy, he's great, helped me when I thought I blew my kirby up, it was just a cord and he wa able to tell me that over the phone. When I called him with this problem, he knew right away that it was only putting out a thin strip in the middle only. The first thing was I needed that little screen, the second was the hole where the screen goes has a white tube that goes from that hole to the bottom of the tank, its kinda in the corner and I never thought it would have anything to do with the problem. He said I needed to run hot water in it and clean it cuz I was going to have to blow in it, yes, with my mouth. I ran it under hot water for a few minutes and then with hot water in the hole, blew into it. I did this a few times, checking the tube ending each time. After a few times, water was shooting freely through the tube. Problem solved, I think, I'll be shampooing tonight so i'll know for sure then. An alternative to blowing with your mouth would be using a can of air, didnt think of it till now and I have 1!
May 30, 2008 | Kirby Ultimate G Bagged Upright Vacuum
No suds when shampooing
The sponge filter is in the large opening on the underside of the kirby shampoo tank. It is where the shampoo tank connects to the kirby. The cap the manual is referring to is the shampooer tank cap. It looks like a cup.
If the mesh screen in the hose is in place (try pulling it out of the hose and seating it in the tank where the hose connects.) and you're still having very little suds...(I'm assuming you're using Kirby shampoo as well)...I would suggest going slower when yours "laying down suds". And lower the shampooer head all the way to its lowest setting. I have found if there are a lot of oils in the carpet, the emulsifiers in the shampoo break down quickly and make the suds "disappear".
Be sure to go back over the carpet with the tank in the off position to scoop up any excess moisture. If excessive oil (from cooking, barefeet, and pets are main causes) is the cause of the lack of suds, numerous shampooings will rectify that situation.
Hope this helps!!
Feb 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
No Suds! It just Spills the water
there is a little plastic round piece with a mesh screen that should go on the hose part of the shampooer that connects to the tank...make sure that its seated properly since it's this mesh screen that produces the suds
Dec 16, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
234 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
