Akai LCT2060 Television Logo
Posted on Feb 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCT3701AD Intermittent initial startup until now. Remote would not turn it on for awhile but power button would. Now, neither will turn it on. Yesterday, we played a DVD on it, ejected the DVD and the TV would not turn off. ( Had this about a year.) So, we unplugged it. Plugged it in this AM and we have a red light, but neither the remote nor the ON button will turn it on. Advice? Is it the main power board?
  • snowdncr43 Feb 03, 2008
    Just found the model number on this TV, it's an LCT3701AD. Do you still think it may be the power switch only? If so, should I change the pcb going to the switch or the switch button itself?
    Any idea where I can get either? The other threads I've been reading indicate that AKAI parts are almost impossible to get.
  • snowdncr43 Feb 04, 2008
    Call AKAI. They simply told me to take it to a repairman. AND they will look up parts for a repair facility (told them we DO electronic repair, just don't have specs on this AKAI) and wouldn't do it for me.
    Looked at the standby (on/off) button and it seems to click well, but haven't removed the DVD player to get to the board that it appears the button is plugged into. Think there's any need for that?
    Also the one hint the guy did give me was "It may be your power source." Any more ideas?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 175 Answers
  • Posted on Feb 03, 2008
Anonymous
Expert
Level 2:
Mentor:
Answers
175
Questions
Helped
79403
Points
315
May be the front switch panel is blown :(
  • Anonymous Feb 03, 2008
    i m not so sure where you can get the parts but i sujjest that you call AKAI customer support
3helpful
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
2helpful
How do you change TV input from antennae to cable.
Thank you for posting your question at FixYa!
To change the TV input from antennae to cable, just press the "source" button on your remote control.
Keep pressing until the cable is selected. Please refer to the image below.
Have a great day.
Remote code wanted
Hello
Three digit universal remote code for Akai TV are: 002/ 0030.
Four digit universal remote codes for Akai TV are: 0105 0002 0077 0254
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
When unit is turned on, it defaults to Vid1. My Direct TV Satellite is hooked up to CMP - component input. Is there any way to make the TV default to CMP when it is turned on?
Bring up the menu on your TV. At the bottom of the menu should be the Setup menu. Choose it and press OK on your remote. You will then get another menu and one of the choices will be Preferences. Highlight it and press OK. On the next menu choose Special Features and press OK. The last menu should have a choice titled Initial Channel. Highlight this choice and then using your Left and Right buttons on either side of the OK button you will be able to scroll through all of your channels as well as all of the Inputs that are on the back and front of your TV. Scroll through the choices until you see CMP. Then you can either highlight and choose the Go Back choices at the top left of each menu, or just press the Clear button on your remote until you exit the menu system.
Now when your turn your TV on it should default to CMP. The same menu that you chose CMP through will also allow you to choose the Initial Volume on startup,
Tv will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
1helpful
Delay light is flashing on tv, but wont turn on. Not sure if problem is tv or remote? Dont see light on remote when push in buttons?
The problem with the unit is power supply part number,MLT166A.If you can not find one you can try to fix yours.First you have to take out power supply,Replace 3 electrolytic caps EC18,EC19,EC20 all are 1000mf at 16 volt.Then find Z3 on same board,it is a 27 volt zener diode 1 watt,part number 1N4750A.Put board back in then unit should work.
2answers
Need Power Supply for Akai LCT3701AD
This post might be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
7helpful
2answers
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
