Raymarine St 4000 Wheel Drive E12093 Logo
Posted on Jan 05, 2010
I HAVE A 1997 AUTOHELM ST4000 AUTOPILOT AND THE
I HAVE A 1997 AUTOHELM ST4000 AUTOPILOT AND THE RUNNERS ATTACHED TO THE BACKING PLATE TO THE WHEEL FIXING APPEARS HAVE BROKEN OFF. EVERYTHING ELSE IS WORKING WELL. CAN REPLACE THE BACKING PLATE? OR CAN I PURCHASE JUST THE WHEEL ASSEMBLY AND WIL THIS BE COMPATIBLE WITH THE EXISTING EQIPMENT
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Apr 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
9258
Points
24
GLUE THE SMALL POSTS EXACTLY IN PLACE AS THEY BROKE OFF ,DRILL A HOLE VERTICALLY THROUGH THE POSTS ,SAME SIZE AS HOLE IN THE SS WHASHER, (HOLE OF THE SCREWS)ALL THE WAY THROUGH THE BACKPLATE ,INSTALL A STAILLESS SCREW WITH HEAD ON THE REAR OF THE BACKPLATE AND NUT ON THE WASHER SIDE TRIM TO EXACT LENGHT USE LOCKTITE FOR NUT.
  • Anonymous Aug 16, 2013
    Thanks - this worked great when I ran into the exact same issue thsi week.
Where do I find the parts number for the clutch lever and pin for ST4000 to order from a marine store?
The clutch lever for the black wheel unit st4000 has Autohelm reference N011,see at Westmarine,is sparepart is available
4helpful
2answers
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
2helpful
2answers
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
1helpful
ST4000 autohelm
The clutch lever shearpin is on the outside through the body of the clutch lever
Top Raymarine Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
