T-Mobile Sidekick® 3 Cellular Phone Logo
Posted on Jan 05, 2010
I dropped my sidekick 3,the screen went black, I played around with it turning it on and off, taking the battery in and out, the xcreen went white, so I repeated what i did earlier. The screen finally started woking but now...it won't read my sim card! What can I do?
The screen on my T-mobile Sidekick 3 went white.
You need to reseat the LCD cable. More than likely it has come loose in the back of the LCD
Follow the guide at the following link.
Sidekick White Screen Repair Guide
5answers
My sidekick 3 has sonething wrong with it.
So if the sidekick has suffered a drop or some other type of trauma, the cable for the lcd screen can come loose causing a white screen. Try the following guide to repair a white screen:
Fix a White LCD Screen on Sidekick 3
If it doesn't work, you can replace the Sidekick 3 screen assembly fairly easily. A new LCD assembly runs about 30 dollars from ebay. Here is a guide for that:
How to Replace a Sidekick 3 Screen
and here is a link to the screens on ebay:
Replacement Sidekick 3 LCD Screens for Sale
Hope that helps
2answers
My sidekick 3 screen is white
take the phones and have the LCD or flexcbale replaced
HELP SIDEKICK 3 WHITE SCREEN!!PLZ
Follow this procedure and it should fix the issue. If not then a new lcd definetly will
Fix Sidekick White LCD Screen
if you don't have a t6 torx driver, a small flathead will do the trick.
Blank Screen???
Is it white or just black?
If it it is white then this procedure should fix it, Fix Sidekick White LCD Screen
if it is black then a new lcd is in order. They run about 45 dollars and fairly simple to install.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
My sidekick id
Is the screen white or black?
If it is white you may be able to fix it, black maybe not.
The following instruction for a sidekick 3 but it is the same for a sidekick ID. Just reseat your lcd instead of installing a new one.
Sidekick 3 LCD Screen Only Replacement
1helpful
2answers
White screen
Honestly, this has happen to me 3 times on such random occasions. My solution...leave it alone. Thats right turn it off leave it to charge over night, when you wake up take the battery out for a bit, then put it back in after fter a little while. I promise you it always works for me. shit it just worked as I'm typing this. Am I sure this isnt part of a bigger problem? no. But it is the best solution, considering T-Mobile wants to charge me 110 to get it "fixed"
Sidekick 3 white screen
Did you by chance drop the phone recently?
A loose cable for the lcd can cause this or a bad lcd.
You need to disassemble it to take a look.
Sidekick 3 Disassembly
You will need a set of Torx screwdrivers to get it open.
1helpful
3answers
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Top T-Mobile Cell Phones Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
