Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Try resetting it.
"It is possible to reset and test the headset. Make sure that the headset is powered off. Press and hold the answer/end button and the on/off button at the same time for 10 seconds. The headset will automatically turn off after approx. 10 seconds. The next time you power on, the headset will go into pairing mode as the first time you powered your new BT2050 on."
Quoted from:
http://www.rtbtechnology.com/document/bt2050_UM.pdf
