Question about Canon PIXMA MP530 All-In-One InkJet Printer
Error 1681 more than one Cyan cartridge installed
My Cyan ink cartridge was low so I installed a new one.  Now my Mac gives me error 1681 more than one cyan cartridge is installed-and I can't print anything.  Please help me solve this problem.
  • 3 more comments
  • John Jobby Feb 13, 2008
    I also get this printing from my Mac (though with my black cartridge). At £11.50GBP ($23USD) a pop, replacing the cartridge every time it happens is not an option. Turning the printer off at the plug seems to re-set it for a short time.
  • Anonymous Mar 17, 2008
    I have the same problem but with my black cart (cli-8bk).  Canon ip4200 and MacBookPro Intel duo core.
  • Anonymous Apr 15, 2008
    have had the same problem but mine says its the yellow. Not sure what to do? Might have to take it to the repair shop
  • Anonymous May 12, 2008
    I am getting error no 1681 (more than one ink tank of the following colour is installed (black). Can anyone suggest a remedy. I would be eternally grateful.
    Mike Dudley
  • p_campioni Dec 08, 2017
    I had the same problem. It is not the black tank but the cyan on its right side, you understand that because the led of the cyan tank is off. If you reinsert more and more time the cyan tank until the cyan led go on you solve the problem
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
Posted on Apr 26, 2009
Just tried the suggestion of holding the midle button down for 6 sec, didnt seem to work. Might just have to buy a new yellow cartridge
Posted on Apr 15, 2008
I have just tried this solution and it has worked (hum, for how long ?) :
Turn your printer off.
Keep pushed the middle button for about 6 seconds (the one that is blinking in yellow, seven times for the error 1681)
Your printer should turn on and work again.
Hope it will solve your / my problem.
Sorry for my poor english Francois
Posted on Mar 19, 2008
Replace the cyan cartridge again. There are quite a few faulty new cartridges getting around. This will fix it everytime. Seen it hundreds of times.
Posted on Feb 04, 2008
6ya staff
SOURCE:
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
Says the cyan ink cartraige is empy but it is new, replaced it with another new one and still says its empty
remove all cartridges and close the lid. Wait for "ink cartridges missing..." error to appear then install all cartridges and close the lid. If the error persists, remove all cartridges then clean the cyan chip and corresponding contacts in the printer with damp cotton bud. Dry well (with dry c/bud) then fit cartridges back in. If still no good, contact HP.
hope this helps
LC1000
www.inkbank.com.au
Dec 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Laserjet 5550dtn printer is giving error 59.51, what will be the problem?
This code means there is a Cyan Cartridge motor error. The most common cause of this error is the Cyan Toner/Drum cartridge is binding up and causing the motor to stop turning. I would try removing then re-installing the Cyan cartridge first and see if it goes away. If not then replace the Cyan cartridge with a new cartridge. If the problem persists then there is a problem with the drive assembly for the Cyan cartridge.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | HP LaserJet 5550dtn Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Installed a new refilled PG-5BK ink cartridge into an MP530 printer and get the error message 1681.
Thats because of usingthe refilled cartridge. Most printers these days have a sensor to detect the use of refilled cartridges, or even generic (3rd party) ones. They do this to prevent customers from buying cheaper 3rd party cartridges. Its kind of unfair business practice, but what to do?
Use an original, new cartridge, and this error will go.
Nov 01, 2008 | Office Equipment & Supplies
Dear all,
To fix this problem, first check which ink blinks, then replace it with new one. If this does not fix your problem, here are possibilities: carriage part error, logic board error. Be careful of short circuitry problem in this case. It may harm other electrical part
Regards,
Related Topic at:
Canon Inkjet Printer Forum
Sep 06, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
4,496 people viewed this question
Clive
Clive
old marine
old marine
Ekse
