I have a samsung pl50 digital camera ive only had it for 2 weeks and all of the sudden when i try to turn it on the lense wont come out! it seems like its jammed or something? i can switch it to play mode bt jst cant take pictures.. i haven't dropped it but the only thing that i can think of is that ive left it out in the sun or got sand in it from the beach... please help
Hi
Thanks
for using FixYa. Please check the battery is fully charged.
If you are able to access the Menu, please select Initialize under Settings and
Main Settings 1 Menu and press OK. If still the issue persists, perform
the power reset by removing the Battery and
pressing the power button continuously for one minute. Then, leave the power
button and reinsert the Battery.
To reset
the Digital Camera by using a RESET
button follow these steps---
To perform a manual power reset follows these
steps---
If still
the issue persists then it means that the cabinet is opened or LCD cable is
touched which is caused by connection defect or poor contact between connector
and LCD cable due to the pressure by the rib in the front cabinet to the
connector. If still its not resolved then as its a new one so you should use its warranty and get it replaced just to avoid future issues.
Please do
accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
