Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an MP530 printer - error message 5C10 is
Error message 5C10 is coming up on screen when I try to print and the alarm light is flashing. Can you help?
Thanks
maree
Anonymous
Level 3:
  • Master 434 Answers
  • Posted on Jan 05, 2010
Anonymous
Master
Level 3:
Answers
434
Questions
0
Helped
190889
Points
1456
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
5C10 faulth in my MP530 Pixma. Who knows the answer(s) Tanks
There is no error 5C10 listed in the MP530 service manual. however count the sequence of how the green and orange lights flash. Repost with this info and i can help you more.
1helpful
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
When I try to print, my Canon Pixma MP 530 flashes an alarm light. The computer tells me it is error number 5C10. Do you know any solutions?
Try power cycling the unit. Turn it off or unplug it for at least 10 seconds. If that doesn't help, the error code means a failure of the ink system. Sometimes replacing the printhead will help but not always. (Printheads are not-returnable.) If a new printhead doesn't help, the only solution is having the printer serviced. This is often not worth the cost versus the prices of new printers with out-of-warranty units.
I hope this helps.
2helpful
Service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
1helpful
Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
The alarm button is flashing and have service error messages for the following: 5C10, 6A00,5C00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
Error code 5C10
From Canon. Issue: ERROR LCD: Error Code 5C10
1. Press ON/OFF switch to reset the multifunction device 2. The MP530 may require repairI would remove the print head and inks,unplug it completely from thr eall for a half hour.Plug it back in and install everything.
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : [email protected]
old marine
old marine
ZJ Limited
ZJ Limited
