Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Banging tumbler during spin cycle
My front loading frigidaire gallery washer makes this real loud banging sound during the spin cycle...it just started happening a couple of days ago....I tried to manually move the tumbler and it fixed the problem for about two minutes,then it started again...Can you please help me or do i need a repairman to come out and adjust the tumbler....or is it another issue?
Thanks for your help.........
  • 1 more comment
  • Anonymous May 25, 2008
    My four-year old Frigidare 3.1 cu. ft front load washer started banging loudly during the spin cycle and we were unable to resolve it by rebalancing the load.
  • willtry May 27, 2008
    My figidaire 3.1 cf front load washer continues to bang ever so loudly during the spin cycle, no matter whether it is full or empty. I replaced the pair of shock absorbers because one was cracked but that did not resolve the problem. The wiper arms are all secure, nothing is under the rubber skirt and the concrete slabs are secure. It sounds like the banging is coming from within the tumbler; there is no banging against the sides of the cabinet.
  • seanmag Feb 16, 2009
    Hi - I have a very similar problem but I think it's the main drum bearing. Is there any point in trying to replace this or would it be too expensive?
    Genius:
  • 1,554 Answers
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Posted on Feb 27, 2008
SOURCE:
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
My frigidaire 417 front loading washer drum bangs around violently especially during "spin" cycle. What can I do to remedy problem?
You never want to over load your machine, when you do some of the heavier clothes seem to go to one side of the machine. When the spin cycle starts and it's making that loud sound, open it up, wait for the spin to come to a complete stop, then make sure clothes are evenly around. Then put the lid back down it should be fine then. If it's not, then repeat above steps. I hope this helps. Thank You for using FixYa.
Jan 05, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Fridgedaire Gallery front loader, was making a loud banging noise on spin cycle, now the whole drum has dropped! help!
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
Oct 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
418 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
