Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Why is the fault F18 error code on my bosch washing machine flashing?
During the wash cycle a f18 error code flashes. the cycle does not finish and the drum is fill of soapy water.
  • 2 more comments
  • Anonymous Nov 19, 2008
    I hadthe same fault code
    I had to open up the small cover on the front of the machine.
    Then drain the water in the washer using the drain pipe.
    I then opened the filter cover and found 46p in change in it!
    Also a piece of plastic.
    After removing these item the washer is now working perfectly
  • Anonymous Mar 15, 2014
    Neff error code f18
  • French Fancies
    French Fancies Jan 16, 2017
    thanks chrismoyler - worked a treat!
  • Mahsa Bakhshi
    Mahsa Bakhshi May 30, 2018
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Posted on Dec 24, 2009
  • 9 more comments
  • veronicarubi
    veronicarubi Feb 19, 2013
    Guess what! I fixed my washer with the instructions above. Thanks. Love the internet!
  • anka_lipicni
    anka_lipicni Mar 05, 2013
    I have this error on the display too. If I turn the knob on the rigt (the grey one) for 15' left, I can't pull it out. What am I missing here? Usually it went smoothly.
  • anka_lipicni
    If I rotate the grey knob for 15' left (can't go left more than that), I can't pull it out. Is is stuck? How can I pull it out?
  • anka_lipicni
    Here is a photo :)
  • Paul Whitehead
    Paul Whitehead Jan 17, 2015
    worked for me :):) thanks
  • Paul Whitehead
    great instructions....u need to pull hard on the white knob to remove it..mine was screwed in just like lid of jam jar...so keep turning anti clockwise till it is open..i needed a pliars to pull it out so i could see the motor behind it and i found 2 nails, a toothpick and a blob of fluff :):)
  • Hall Kirkham
    Hall Kirkham Oct 08, 2015
    You just helped me fix my washing machine and restore my cred with the wife! Thank you!
  • Michelle B
    Michelle B Apr 03, 2016
    Excellent instructions just did this and found three hair grips and a load of gunk! Machine good to go Thank you!
  • Abbie Bates
    Abbie Bates Jan 23, 2017
    Brilliant just fixed my washer saved my neck from the husband. Thank you
  • Anonymous Mar 31, 2017
    Thanks for this. Just saved me some money on a callout
  • Michael Smith
    Michael Smith Apr 06, 2017
    Thank you it is now fixed just saved me money most grateful
    Sniper:
  • 71 Answers
The Manual states
F18 Clean the detergent/solution pump (see page 10) or ,check that the outlet pipe/drainage hose is not blocked.
Best wishes karen
Posted on Jul 18, 2009
  • 1 more comment
  • FGoldwin May 18, 2011
    Very good instruction, but in my case it didn't help. I removed the white knob and there was no debris to clear. Instead in the channel/pipe (a bit in to the left) from where the water comes down to the pump rotor there is a coin. I can reach it with my fingers but I am unable to pull it out. I have tried with different tools without any success. The question I have: Is it possible to remove the low part of the front panel in order to access this channel/pipe where the coin is? There is a screw to the right of white knob. When I remove this screw the right part of the panel is lose but the left part is stuck and I can't find any more things to unscrew.
  • Stewart Taylor
    Stewart Taylor Aug 21, 2018
    Once your taken the screw out slide the whole bitten panel to the right..it hooks into the unit on the left..give it a general tap to the right and it should come off..
  • Anonymous Dec 27, 2018
    In our model (in Greece) the panel does not slide, it pops out pulling it forward. We had a lot of junk (pieces of small garments, coins, etc stuck in the flexible pipe *before* the pump.
This can also mean that the waste is blocked as i found out today. There was a twist in the waste pipe stopping the water leaving the machine so don't forget to check this also.
Posted on Jul 22, 2012
  • Bambram Jul 22, 2012
F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display
Diver 1
Posted on Feb 08, 2008
    New Friend:
F18 error?
First do what is suggested above.
Switch machine to off.
Then switch to drain. 1 min later it should finish.
Remove the white cover bottom right.
Drain excess water into low oven dish by pulling the plug from the little black hose.
Then using long pliers twist the blue\white circular anti clockwise. It is likely to be very stiff so be gentle or you'll crack the plastic. Clean this out. You'll find something in there. Check the little impeller at the back can turn.
Run a short cycle.
If you get another F18 error it's likely that you need to pull the machine out from the wall. Check the drainage hose where it connects to the outlet pipe. If it's full of fluff (and it stinks!) you've found the problem.
Clean it thoroughly. And the outlet pipe if you can.
Run a cycle and the problem should be gone.
Why is the fault F18 error code on my bosch washin - 2_6_2016_12_33_39_pm.jpg2_6_2016_12_33_40_pm.jpg
Posted on Feb 06, 2016
  • Connie Shoffit Haworth
    Connie Shoffit Haworth Mar 19, 2017
    Thank you so much. Fixed my problem right away!
Thanks to your above answers, I just fixed my washingmashine! Thanks!
Posted on Jan 13, 2012
    Top Expert:
  • Bosch Master
  • 5,691 Answers
Drain error. Check Pump and filter
Posted on Dec 05, 2018
    New Friend:
  • 44 Answers
Error F18 means problem with the drain pump
F18 is a pump timeout error - if you cannot hear the drain pump trying to empty the water when you select a drain or spin cycle, then the pump is the problem.
Posted on Feb 03, 2018
Looks like the pump just needs cleaning out (service flap on front). I have not tried this yet. Ours has the same error. I got this info from someone else, but it's worth a try. Gonna do ours when i get home.
    New Friend:
Thanks for the answers,just fixed my machine.
Posted on Jan 15, 2013
F18 is flashing on a Bosch front loader washing machine ( Logixx8 Sensitive)?
If it is a F18 error,t means that the pump out time is too long. Most likely clogged filter.
Open panel on the bottom right, drain the water out using the left hose and remove the filter plug. Have a look and clear obstructions.
That should help.
Sep 10, 2017 | Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
F18 ERROR ON WASHING MACHINE
have you CHECKED the filter is clean
leave feed back
Jan 09, 2014 | Washing Machines
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
I was washing today and at the end of every wash tere was a code of f18 flashing on my screen .what should i do
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins.
Jan 06, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
75,129 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
