On my Xerox ColorCube 9201, can it be set so that incoming faxes print to top tray and everything else to the stacker?
Yes. If you press the login key( admin : 1111) then hit machine status(left side) there is a tab on the touch screen that says tools. If you go under fax settings or default fax settings it will be a option labeled as output destination. You can also find these setting if you type in the ip address of the mfp in your web brouser (same user name and password required). Hope this helps!
