Learning Curve Toys Thomas the Tank Engine Train and Friends: Water Tower Figure 8 Set Logo
Posted on Jan 04, 2010
Hi I have been given a Take Along Thomas Water Tower. The water tower has no water in it. How do I top it up?
1helpful
Indesit di620 dishwasher not spraying water from arms
Hi, you may want to try looking at all the holes in the spray arms. If you see anything blocking a hole, use the tweezers and remove the stuff.
Remove the bottom spray arm and check for items in the water delivery hole.Check the lower spray tower that is connected to the bottom rack. Make sure all rotating parts rotate properly. Look underneath to make sure nothing is stuck in the tower. Remove any stuff stuck that is preventing rotation or clogging the tower.
Jun 26, 2011 • Dishwashers
12helpful
2answers
Hi, "Santa" was nice enough
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Jan 23, 2011 • Toys
3helpful
The spay tower in the bottom fell out. should
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
4helpful
Top rack not being cleaned?
Make sure the water tower is not blocked so it can rise to that level. Check the condition of the tower by pulling it up gently. If it sticks, don't force it.
I have a frigidaire ultra quite modle number fdb126rbs1 there is a a spout with a rubber flap on the end and it is shooting water out of it with a lot of presure?
Hi, lilztheman
You said,
I have a Frigidaire ultra quite model number fdb126rbs1 there is a a spout with a rubber flap on the end and it is shooting water out of it with a lot of pressure?
And is the water inside your dishwasher and cleaning your dishes??
Please clarify what the problem is and what's wrong.
Where is it shooting pressured water too?
This dishwasher has the older tower type spray system inside the dishwasher.
It consists of a number of tower like tubes that fit one inside the other by the water pressure and they all are pushed up into each other to create a tower which sprays the dishes clean with high pressure water.
At the top of the tower is a plastic cap to direct the water with pressure in all directions!
Please tell me in detail what the problem is so I may suggest a solution.
Sep 17, 2008 • Dishwashers
Water tower
I had the same problem finding a Water Tower laying in the bottom of the dishwasher. Solution is to simply lift the bottom rack and insert the tower into the center-most square hole. Twist the tower with the large lip on the bottom of the rack and the two plastic pieces will overlap two sides of the square hole. It will come lose again in time, but just reset it again.
Top Learning Curve Toys Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
