It is possible to repair a Skytech 3002 receiver that has corrosion or a broken battery spring, but it will depend on the extent of the damage.
If the corrosion is minor, you may be able to clean it off using a soft cloth and some isopropyl alcohol. However, if the corrosion has caused damage to the electronics inside the receiver, it may be difficult to repair and you may need to replace it.
Similarly, if the battery spring has simply come loose, it may be possible to reattach it or replace it with a new one. However, if the spring has broken off completely, it may be difficult to repair and you may need to replace the receiver.
To replace it you can get a discounted one below
https://amzn.to/3EEZEsX
New battery cover, that is. Binoculars fine. Battery cover/holder needed.
This battery cover is the exact same thing.https://www.bakermarineusa.com/product-p...
