SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
SOURCE: Transfer file to Archos 5 using usb port on DVR Station Dock
On your Archos 5 go into tools -> Files and you should have two Archos 5 tabs. Change one to your USB stick and the other to the Archos 5 and copy and paste. I have not tested this, but this should work. Good Luck.
www.blogger.usarchos.com
SOURCE: Archos 605 running Vista Computer does not recognise the archose
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
SOURCE: My archos wont connect to my computer
i had this problem. you have to use a high speed usb port (2.0 i think) which is normally in the back of your computer and then it should be detected
SOURCE: Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
