My capri watch has broken where the strap fits to the actual watch. The plastic hinge has snapped. This is unrepairable and thus renders the watch unwearable, any ideas?
Unless the watch has a unique design on lugs for the strap, you should be able buy a strap that is interchangeable with the existing one form most watch shops.
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted. Don't forget to rate, please.
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Please call this number 1-718-7298600 x 272, order a strap for kc1232, usually it takes you 7 days to receive this strap, and there will be four new screws comes with your order, I believe it cost you $18.00 to have new strap.
