LG 32LX1D 32 in. LCD Television Logo
Posted on Jan 04, 2010
My lg lcd turns on.then turns of - LG 32LX1D 32 in. LCD Television
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
633
Points
Unexpectedly Turning Off
Many LG LCD television owners have reported a problem
where their television will power itself off or will only work
for short periods of time.
The problem usually occurs in brand new televisions and requires
the television to be sent to LG or your local electronics repair
shop to be repaired.
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
2answers
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
When I turn the tv on, the green power light comes on and then immediately turns off, (light goes red). No image or anything comes up on the screen. Never had any problems before this. Checked all plugins....
Use the remote to switch problem,if it's not works,I am sure the power board problem
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
12helpful
4answers
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
BLACK SCREEN WITH COLOURED LINES ON LG KF700. BATTERY WENT OFF, TURNED BACK ON AND HAD THIS PROBLEM.
Sounds like your lcd screen is damaged. Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
LG KF700 LCD Display Screen Replacement
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
LG LCD 37'' standby problem
if you want i will buy the tv from you
TruMotion
dont put the LCD neaer magnetic things like speaker or ampilifier......when the problems happend?
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
