Nintendo DS Lite Console Logo
Posted on Jan 04, 2010
Ds lite bottom screen,lcd gone funny,there are funny pattern on screen
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
2049
Points
8
It's likely the bottom LCD screen has been damaged in some way (or smashed) the bottom LCD will need replacing (touch screen may need replacing also)
1helpful
I changed the battery on my ds lite and the touch went funny
Possably it depends how it gets on for a couple of days
1helpful
My nintendo lite wont turn on-the green lite is on but thats all-
Which LCD is blinking?
If your top screen is blinking before cutting off, your DS lite has a problem with the bottom screen.
If the bottom screen blinks before cutting off, your DS lite has a problem with the top screen.
Can you confirm?
2helpful
2answers
Potentially dead Nintendo DS lite LCD screen. (bottom)
Hey, I can help you.
Yes, the Bottom LCD is dead. You will have to exchange it.
Below I have two links you should follow through. One to purchase a bottom LCD for a very cheap price and the other will show you how to replace the bottom LCD.
REMEMBER.. To place a plastic pad under the bottom lcd so it doesn't ground out the board. Forgetting to do this could potentially blow a fuse and you will have to replace those!!
1.) http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
2answers
Nintedo DS Lite turns off when using touch scree
check the main supply of the lcd and replace the voltage regulator
2answers
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
1helpful
3answers
Ds not lite
Replace the connector cord between two screens. You can buy new ones from DX Deal extreme! Carefully remove through hinge and attach securely.
Be careful not to break the fine wires connecting. Have to twist the connector cord in the correct way to make it go through hinge without damaging.
Good luck cos it is a fiddly job.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
