this covers all apple i products
When you connect your device to your computer, items automatically
sync according to your preferences set in iTunes. You can, for example,
enter email addresses of friends and family members on your computer,
connect your device to sync, then unplug it and tap a friend's email
address on the touchscreen to email them.
You can sync
- Contacts-names, phone numbers, addresses, email addresses, and so on
- Calendars-appointments and events
- Notes (sync with Mac OS X Mail* or Microsoft Outlook)
- Web bookmarks
- Music and audiobooks
- Photos
- Podcasts
- Movies and TV shows
- Applications
- Ringtones (iPhone only)
- Books
- iTunes U content
Note: On iPad, you can also sync documents via File Sharing with apps that support it.
You
only need to set which items are synced in iTunes on your computer
once. After that, just connect your device to start a sync.
Contacts,
calendars, notes, and bookmarks are synced from (or to) your computer,
so if you add, change, or delete them on the device, they are changed
on your computer, and vice versa. You can also sync contacts with your
Yahoo! or Google Address Book.
Email-account settings, music,
movies, TV shows, podcasts, and photos are synced one-way, from your
computer to your device (though you can import photos taken with iPhone
to your computer and you can transfer purchases from your device to
iTunes). Using an iPad, you can send photos back to your computer
(typically captured on iPad via the Camera Connection Kit).
If
you like, you can set your device to sync with only a portion of what's
on your computer. For example, you might want to sync only a group of
contacts from your address book, or you may want to sync only songs
from certain playlists so you don't fill your device with your music.
* Syncing is over USB only and on a Mac requires Mac OS X v10.5.8 or later.
Set up syncingYou
use iTunes on your computer to choose which items to sync. Make sure
you have the most recent version of iTunes (on a PC, open iTunes and
choose
Help > Check for Updates. On a Mac, open iTunes and choose
iTunes > Check for Updates.)
1. Connect
- Connect your device to your computer using the included cable. By default, iTunes opens automatically.
- Select your device in iTunes under Devices on the left-hand side and click the Info tab.
2. Choose which items to sync
Click the respective tabs in iTunes to specify which media and information you want to sync from your computer to your device.
For more information about syncing your device with your computer, see the User's Guide:
3. Sync
Click Apply in the lower-right corner of the screen. Your computer syncs with your device according to your settings.
The
first time you sync your device, you are asked if you want to merge
data, replace data on the device, or replace the data on your computer.
When you choose to merge information, any differences between the data
will be mingled together. If you choose to replace information,
information from either the computer or device will overwrite the
information on the other. These options can not be undone. After that,
anytime you connect your device to your computer, iTunes opens and syncs
with your device according to the settings in iTunes.
You can adjust sync settings any time your device is connected to your computer.
Note:
Syncing won't delete any contact in Yahoo! Address Book that contains a
Messenger ID, even if you've deleted the contact from your address book
on your device or your computer. To delete a contact containing a
Messenger ID, log in to your Yahoo! account online and delete the
contact using Yahoo! Address Book.
i connect the phone but it would not installed in the computer
dont know how to put music to my LG VX8500
ya it wont connect to the computer it say si have to downlaod somthing???
