Thanks. We have replaced our PC100/REG 64MB/ECC with PC133/ 128MB NON ECC ram. Now my server is working fine for more than 16 hours. We hope we have solved our problem. We have tried with PC100/ 256 MB non ECC ram in this server. It is not working. What i want to know is how much RAM this server supports. there are 2 memory banks are there. In E-Bay , USA this PC100/REG 128MB/ECC is available. Make "MASTER". Can i try that. Pl give suggestion.
you will need to select your motherboard from a dropdown list
also on the left will be types of ram ddr2 ddr3...... you will need to select which type you have
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory.
ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses.
Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory.
hope this helps you
Registered/Buffered - Registered or buffered modules delay all information transferred to the module by one clock cycle. This type of memory is primarily used in servers.
Fully buffered - Designed for next-generation servers, features an advanced memory buffer.
CL - CAS (column address strobe) latency, which is the number of clock cycles it takes before data starts to flow after a command is received. Lower CL is faster. Modules with different CL can be mixed on a system, but the system will only run at the highest (slowest) CL.
Component configuration - (For example: 64Meg x 64) Indicates the size of the memory chip components on the module.
Voltage - For example 2.6V. Indicates the power used by the module. The lower the better. Check the glossary and FAQs for more detailed definitions.
hope this helps you
