From
the main menu choose "Parental Controls;" it's option six.
Choose
the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK
button on the remote, scroll through until the TV-MA rating appears. Press the
right arrow button to move the highlight over to the "Status" field
and toggle to "View." Press the OK button. This will set the
age-based ratings to Mature.
From
the Parental Controls menu, select the second option, V-Chip Movie Ratings
Limit and change the rating to TV_MA and the "Status" to
"View."
From
the Parental Controls menu select the third option, V-Chip Unrated Program
Block and select item one, which will be "View."
Select
the fourth option, which is "Channel Block." Highlight the Channel
field and using the channel up and down buttons, go through and check they are
all set to 'View." Any set to "Block" will need to be toggled
back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu. If you wish more details abut RCA TV unlock proceedings, check this site.
Turn
your television and Apex DT250 receiver on.
Push
the "Menu" button on the Apex DT250 remote control.
Press
the remote's "Up" and "Down" buttons to scroll through the
menu options. Stop when "Parental Controls" is highlighted. Press the
"Right" button to select this option.
Enter
your four-digit password. If you have not set your password, use the default
code of "0000."
Use
the "Up" and "Down" arrows to change or set the parental
control movie ratings. You can select from "None," "G,"
"PG," "PG-13," "R," "NC-17" and
"X." Once your setting is highlighted, press the "Right"
button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
From
Choose
From
"View."
From
Select
back to View.
