D-Link AirPlus Xtreme G DWL-2100AP (DHDWL2100AP) 802.11b/g Wireless Access Point Logo
Anonymous Posted on Jan 04, 2010
Can't open DAP-1150 configuration utility
I can't open the DAP-1150's web browser-based configuration utility. I've gone through all the troubleshooting steps in the manual (verify physical connectivity, disable firewall temporarily, reset IE Internet Options, etc) but still get an "unable to connect to webpage" message in IE8 when I type in http://dlinkap in the address bar. What have I missed? How do I get to the configuration utility?
  • Anonymous Jan 04, 2010
    Thanks for the quick reply Geekman! Your suggestion alone didn't solve the problem. I checked Whirlpool forums as well and found that I needed to give my pc a static IP first. Thenhttp://dlinkap worked fine.
Anonymous
Level 3:
  • D-Link Master 32,281 Answers
  • Posted on Jan 04, 2010
Anonymous
D-Link Master
Level 3:
Answers
32281
Questions
Helped
7904955
Points
102259
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
2answers
I configure a DAP-1150 and can connect via a laptop but my iphone and ipad fail to connect it. However, when I reset the DAP (with no security), the opposite happens! It means that my iphone and ipad can...
That is because your laptop has the saved connection history that you need to delete. Since your acces point does not have security which is not the same as the one that saved from your laptop. Therefore, your laptop won't be able to connect. Go to network and sharing center and from the left side of the page that came up look for change wireless adapter settings and click it. You will be able to see the connections that was saved and the top one would be your connection name. Delete that and close everything. Try connecting to your wireless network again and that should resolve the issue.
5helpful
2answers
I cannot configure the DLink DAP 1150 access point .As said in the manual When I put the user name and start it says that password is not valid.what is the solution?
Reset the device, unplug all network cable before power on (to turn off dhcp function). After that connect the network cablethe ip device should 192.168.0.50 and subnet mask 255.255.255.0. Set your computer ip address to 192.168.0.xxx where xxx is not 50. Access the device via your web browser, the login page should be apear. User : admin, password : leave it blank
4helpful
2answers
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
32helpful
10answers
Configuring DAP-1150
address to access d-link DAP-1150
http://192.168.0.50
you have to make sure that your ip address is around 192.168.0.xx
Access web configuration
Note: Not all D-Link routers, print servers and access points have a web-based configuration utility. Please check the manual for your particular product. In particular, the DWL-900AP does not have a web utility while the DWL-900AP+ does have a web utility. You cannot gain web-based configuration utility functionality for the DWL-900AP by installing the DWL900AP+ utility. When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet or have to be connected to the Internet. The device has the utility built-in to a ROM chip in the device itself. Your computer must be on the same IP subnet to connect to the web-based utility. Make sure you have Java enabled and are using an updated web browser. We recommend the following: Internet Explorer 5.5 or higher Netscape 6 or higher Mozilla 1.2.1 (5.0) or higher Opera 6.0 or higher Safari 1.0 or higher (with Java 1.3.1 or higher) Camino 0.7 or higher Firefox 0.8 or higher -------------------------------------------------------------------------------- Internet Explorer 6 (SP1) users: If you continue to receive Error 500 when trying to connect to the web-based configuration of your D-Link device, make sure you have the latest Windows update for Explorer 6. -------------------------------------------------------------------------------- If you have Windows XP or Server 2003, you must download the latest Java patch from www.java.com. Click here to download patch - http://www.java.com/en/download/index.js... To resolve difficulties accessing a D-Link model that has a web utility, please follow the steps below. Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. What type of cable should I be using? - http://support.dlink.com/faq/view.asp?pr... Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer - http://support.dlink.com/faq/view.asp?pr... If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Click here to set a static IP address on your computer - http://support.dlink.com/faq/view.asp?pr... Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link routers, Access Points and Print Servers.
Access configuration
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
