Maytag Appliances Over-the-Range Microwave Oven Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave runs constantly
When we close microwave oven door, it starts to run, light off. No heat, just fan and plate move. We can program it to run, but still no heat, and when time expires, it just keeps running. Only opening door causes it to stop running.
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409439
Points
5205
You have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
  • Amye S Brown
    Amye S Brown Mar 02, 2014
    Can you tell me this in layman's terms? I have no experience in these types of problems and need specific info about what to test and how to test it.
1helpful
Kenmore Microwave model Fan running and light on when door closed.
This is normal. Kenmore microwaves will stay running with fan and light on for a short time after food is cooked. The reason is to air out the microwave after cooking. Things like pop corn, Bacon etc. have strong smells after cooking. The ventilation helps to remove odors.
1helpful
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Samsung microwave runs when door is closed
1.check fuse
2.check relay (microwave oven magnetron)
Fan continuously runs, have to leave door open
Check the door switches with digital meter, usually find one bad one. Set meter to ohms and test, some will be normally open and others closed, check with the door open and closed.
Ge microwave fan runs when door is closed and light still on
There are one or two door switches that are probably defective, that must be replaced.
2helpful
2answers
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Sharp R-1750 Microwave
the door switches need adjusting. remove casing and adjust door switches
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
1helpful
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
