Casio BabyG Shock Crystal Strap BG361 2B Watch for Women Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i work my baby g shock watch i lost the instrustion book so i cant work it now im trying to set my alarm clock and put it to beep every hour
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291840
Points
7081
Go to the Casio web site.
Select "Support"
Select "manuals"
35helpful
2answers
How can unmute my watch. even the alarm tone is on mute.
Um, well I had the same problem on my baby-g watch, but i fixed it so here:
- dunno if this'll work, but hold the bottom left button for a long time. never let go till you here a beeping noise. like DO NOT let go. like this is a g-shock and not a baby-g, i dunno where the mute is indicated, but u might see it somewhere. so, just do that dunno if it works as, again, i have a baby-g. good luck! :)
1helpful
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 • Watches
9helpful
3answers
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
1helpful
CASIO Baby G Shock Watch BG905B cannot turn off hourly beeps. I want to turn off all alarms and beeps
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
7helpful
3answers
Please I need to put the clock in hour and I don't understand like one makes
Here is the link to your watch manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2600&submit.x=60&submit.y=11
Save it on your PC and follow instructions how to set an hourly alarm.
Don't forget to rate, please.
95helpful
Shut off hourly alarm on g-shock
Okay I have this module so here goes.
Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
Press 'mode' button (lower left) once. You are now in alarm mode.
Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
Press lower left button to return to normal display.
Hopefully - enjoy the peace!
9helpful
Casio baby G watch model 3786 (can't change digital time)
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
39helpful
Setting the clock on my baby g shock watch
Press & hold the adjust button until the time starts to flash.
Press mode button to select hours.
Press forward or reverse button to move hour backward or forward.
Press mode button to select minutes.
Press forward or reverse button to move minutes backward or forward.
Repeat the process for the month/dte/dy/yr
Press adjust again when finished
Mar 09, 2008 • Watches
1helpful
2answers
Alarm/Beep
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
