Microsoft Windows XP Home Edition Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i unlock my windows xp - Microsoft Windows XP Home Edition
Anonymous
Level 3:
  • Master 581 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
Answers
581
Questions
0
Helped
192797
Points
1559
Windows XP includes a new Microsoft Natural Keyboard shortcut to lock your computer. Any other compatible keyboard that includes the Windows logo key and the Application key can also perform this task.To use this shortcut, press the Windows logo key+L. The following list has different computer lock-up scenarios that are available to you, as well as other ways to lock the computer: Fast User Switching Enabled loadTOCNode(2, 'moreinformation'); If the Fast User Switching feature is enabled and you lock the computer, you can observe the same behavior as if you switched users: The computer returns to the Welcome screen and other users can log on to the computer. Fast User Switching Disabled loadTOCNode(2, 'moreinformation'); If the Fast User Switching feature is disabled and you lock the computer, the Unlock Computer dialog box is displayed that requires the current logged-on user to enter a password to unlock the computer.
Do not have administrator or password for my dell laptop how do i unlock
what windows are you using windows xp windows vista 7 or windows 8
tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 • Computers & Internet
tip
I used Windows Password Unlocker to reset Windows Vista password. Windows...
1) Hope you learn from your mistakes for the next time. Write the password down and put it in a safe place... and remember where you put it. Or better yet, use a password that makes sense to you... Or the best of all, create a Password Reset Disk (details abou this here: http://support.microsoft.com/kb/321305)
2) The "brute force" alternative: Re-install Windows from its installation CD/DVD (which I hope you didn't lose too). This will erase all programs and files you have in your computer. You'll need your Product Key (you have this, right). You may want to try to do an "update previous instalation" (which will keep your programs and files), but it may not remove the password at all.
3) Get a password recovery tool (for free, if possible). Many Windows versions (especially XP) do not like if you just 'delete' the password from an account, like some programs can do. If you do this you may lose access to many files and programs. This a security feature embedded in Windows.
a) Ophcrack: This Windows password cracker is by far the best free Windows password recovery tool available. It's fast and easy enough for a first time password cracker with a basic knowledge of Windows.
With Ophcrack, you don't need any access to Windows to be able to recover your lost passwords. Simply visit the site, download the free ISO image, burn it to a CD and boot from the CD. The Ophcrack program starts, locates the Windows user accounts, and proceeds to recover (crack) the passwords - all automatically (access to files and programs will be kept, so you will regain full access to the computer).
In a test on a Windows 7 PC, Ophcrack recovered the 10-character password to an administrator account in 40 seconds. Ophcrack supports Windows 7, Windows Vista, and Windows XP.
Download Ophcrack from here (choose the correct OS): http://ophcrack.sourceforge.net/download.php?type=livecd
b) Offline NT Password & Registry Editor: This one works basically by erasing your Windows password instead of recovering it (ths is where you can lose access to some files and programs). You can then simply log in to your account without entering a password.
Like Ophcrack, you boot to a burned CD created with the Offline NT Password & Registry Editor ISO file.
If you like this "password deleting" strategy then I highly recommend this program. Offline NT Password & Registry Editor works basically the same way as PC Login Now, but this program is free.
I tried Offline NT Password & Registry Editor on a Windows XP PC and it worked immediately without problem. It should work equally well with Windows 7, Windows Vista, Windows 2000, and Windows NT.
There are some other utilities out there. I'll post them here as I can.
on May 04, 2010 • Computers & Internet
OSD LOCKED.
OSD probably refers to on screen display. and since the error message specifically states Windows XP you can eliminate anything that is not running Windows XP as the OS so likely suspect is #1.
How do you unlock the touchpad?
Unlock? You mean a Password is set? If so, which Password?
Bios Password? Hard Drive Password? Windows Welcome Screen User Login Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
tip
All - in - one Password Recovery Kit for Windows, Ms Office, Pdf, Sql..
Life is so busy that we often forget the passwords like windows, our FDF, office, Outlook password, Internet password and so on. What should we do when we locked out? How to unlock the passwords and get there with the easiest way? Today, I recommend a very good tool Password Recovery Bundle for you.
Password Unlocker Bundle 5.0 is a pioneer password recovery software with intuitive graphical user interface, but not DOS-like black screen, so that it is much easier to reset the Administrator passwords rapidly and conveniently in case the password is forgotten or lost in Windows7/ 2000/2003/NT/XP/Vista/2008. No need to re-install the operating system any more.
Password Unlocker Bundle 5.0 includes : Windows7/ 2000/2003/NT/XP/Vista/2008 password unlocker, Office Password Unlocker 4.0, PDF Password Unlocker 4.0, RAR Password Unlocker 3.0, ZIP Password Unlocker 3.0, MS SQL Server Password Unlocker, Internet Explorer Password Unlocker 3.0 , IM Password Unlocker 3.0, Access Password Unlocker 3.0, Outlook Password Unlocker 3.0 and Outlook Express Password Unlocker 3.0
Now, let's know about the tools one by one.
Lost or forgot Windows 7/XP/Vista/2000/NT/2008/2003 password? Windows Password Unlocker helps to recover Windows password with no data loss!
Can't view or modify password protected MS Office documents? Office Password Unlocker offers series of MS document password recovery solutions
Have password restrains to access PDF format file? PDF Password Unlocker recovers PDF password!
Want a WinRAR/RAR password cracker? RAR Password Unlocker can help to find the hidden password out!
Don't know WinZIP/ZIP password, or can't extract archives from password protected ZIP file ? ZIP Password Unlocker uncovers the password!
Have been locked out of MS SQL database? MS SQL Server Password Unlocker instantly resets SQL/SA password encrypted in master.mdf!
Have lots of Internet passwords and forgot them? Internet Explorer Password Unlocker instantly recover Internet Websites password!
How to recover Windows Live/MSN password, GTalk password or AOL password? IM Password Unlocker is the Instant Messengers password recovery to find those passwords out!
Can't remember the .mdb database password? Access Password Unlocker finds it back in a minutes!
Forgot or lost Outlook E-mail password? Outlook Password Unlocker helps you to find them out in a snap!
on Feb 10, 2010 • Computers & Internet
2answers
I have forgot my password so how do I reset my password?
Read the articles from here:
<a href="http://www.recoverlostpassword.com/article/unlock-win7-password.html">unlock windows 7
password</a>
<a href="http://www.recoverlostpassword.com/article/recover-windows-password.html">recovery Windows
Password</a>
<a href="http://www.recoverlostpassword.com/article/crack-win7-password.html">crack window 7
password</a>
<a href="http://www.recoverlostpassword.com/article/bypass-win7-password.html">bypass window 7
password</a>
<a href="http://www.recoverlostpassword.com/article/break-win7-password.html">break window 7
password</a>
<a href="http://www.recoverlostpassword.com/article/lost-windows-password.html">lost windows
password</a>
<a href="http://www.recoverlostpassword.com/article/change-xp-password.html">change xp password</a>
<a href="http://www.recoverlostpassword.com/article/change-vista-password.html">change vista
password</a>
<a href="http://www.recoverlostpassword.com/article/remove-xp-password.html">remove xp password</a>
<a href="http://www.recoverlostpassword.com/article/remove-vista-password.html">remove vista
password</a>
<a href="http://www.recoverlostpassword.com/article/crack-vista-password.html">crack vista
password</a>
<a href="http://www.recoverlostpassword.com/article/bypass-vista-password.html">bypass vista
password</a>
<a href="http://www.recoverlostpassword.com/article/bypass-xp-password.html">bypass xp password</a>
<a href="http://www.recoverlostpassword.com/article/break-xp-password.html">break xp password</a>
Forget unlock code
Good Day!
You forget the unlock code of what operating system?
Windows XP, Windows 2000, Windows Vista, Windows 7?
Thanks and God Bless!!
1helpful
2answers
How to remove you may be a victim of software counterfeiting from my system?
Install a Tweak Software "Unlocker".. you will find it by googling.. then boot the windows in "Directory Services Restore mode".. delete any files starts with wga*.* at c:\windows\system32 folder.. It refuses to delete and immediately unlocker starts.. select "Delete" from left side dropdown in Unlocker and Kill the processes shown... restart the system
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
