Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green light continues to blink. TV does not power up for Mitsubihi model WS 55513 TV
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302333
Points
1655
Howdy,
Try these ;
1. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001.
2. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V).
The board is on the left hand side of TV from the back. It is standing up, in a silver box.
Good Luck, BIG IRISH.
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
The green light on my tv are blinking and the tv wont turn on
Get a blinking light repair kit from www.TvRepairKits.com - this model has some capacitors on the DM board that need to be replaced.
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
2answers
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
4answers
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
11helpful
2answers
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
3answers
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
2answers
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
