Mitsubishi WS-55511 55" Rear Projection Television Logo
Posted on Jan 04, 2010
Is there any problems with playing Nintendo Wii with the projection Tv?
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jan 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
2352
Points
19
It can be the projection tv doesnt work with the wii console change the projection tv for other one
3 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 16, 2009
SOURCE: Is playing video games bad for my TV
Absolutely not. Your set is the safest type of tv to play games on. Plasma sets are the worst type to play games on due to screen burn in. You are good to go.
Anonymous
  • 208 Answers
  • Posted on Mar 19, 2010
SOURCE: Will my Wii play on this?
Yes, should hook up alright
Anonymous
  • 6 Answers
  • Posted on Dec 30, 2010
SOURCE: I don't have a problem i would just like to ask
Well I don't have a GE but I do have a JVC HD 56G787 which is a 56" and it works fine for wii and PS3 move.
Wii only in black&white
This is a common problem and it is not specific to Wii Fit Plus, it is a TV setup issue.
Access your TV's menu screen and be sure that your TV screen is expecting input from "AV" or "Video". If you have "S-Video" selected, this is the cause of why your Wii is playing black and white.
Wii plays in black and white
That happens when your wii and your Tv set don't have the same region, for example a PAL TV and a NTSC Wii, some TVs have the option for changing the input region mode. An European wii will always be PAL and an american wii will always be NTSC.
How did the prince find rapanzel
Nintendo Wii Errors- How to DIY Go online to find experts that may guideyou step by step.These men online may show you how to fix your console just asan experienced repairman would fix it, but you won't even pay $5 to most ofthem! All these problems can be completelyfixed by you without the use of any external agency. Nintendo Wii: Memory Management, Gamesand Disc
1. Nintendo Wii: Data management
2. Nintendo Wii: How to Copy data to SD card
3. Nintendo Wii: SD Cards
4. Nintendo Wii: Making sure your SD card is compatible
5. Nintendo Wii: Known compatible devices Image files 6. Nintendo Wii: Known compatible devicesMovie files 7. Nintendo Wii: Error Message Disc couldnot be read/Unable to read the disc 8. Nintendo Wii: Cleaning game disc 9. Nintendo Wii: Disc ejecting automatically(including "An error has occurred eject disc") 10. Nintendo Wii: Games freeze while ingame play 11. Nintendo Wii: Message "Disc NotRecognized" 12. Nintendo Wii: Message "An ErrorHas Occurred" 13. Nintendo Wii: Disc Problems requireNintendo Service 14. Nintendo Wii: Erasing Game CubeMemory Card Data NintendoWii: Common problems 1. Nintendo Wii: Fixing time settings forloss time 2. Nintendo Wii: Delay response(display/video and audio) 3. Nintendo Wii: Can't get past"Language Select" screen 4. Nintendo Wii: Hard/Soft reset How-to 5. Nintendo Wii: Character/Cursor move ontheir own 6. Nintendo Wii: Adjusting the ParentalControl Settings of the Wii console Nintendo Wii: Error message "MessageBoard Data is full" 2. Nintendo Wii: Warning message "Becareful about posting too many messages" 3. Nintendo Wii: How do I replyto a Memo? - Why Can't I reply to a Memo? 4. Nintendo Wii: Multiple messages beingreceived from Nintendo
5. Nintendo Wii: Unable to receive emails with images attachment NintendoWii: Repairing and Disassemble Guide 1. Nintendo Wii: common error code listand description. 2. Nintendo Wii: disassemble guide 3. Nintendo Wii: Internal fan replacementguide 4. Nintendo Wii: DVD Drive playerreplacement guide 5. Nintendo Wii: Repairing DVD drive NintendoWii: Balance Board Problems 1. Nintendo Wii: How to fix problemssynchronizing the Wii fit balance board 2. Nintendo Wii: Wii Fit - TakingConsistent body test measurements Nintendo Wii: Wiimote/Remote common problems 1. Nintendo Wii: How to Sync a controller 2. Nintendo Wii: All Wii remotes will notsync with console 3. Nintendo Wii: Cursor is off center,jerky, erratic, or disappears etc. 4. Nintendo Wii: Remote buttons aresticky or stuck down. 5. Nintendo Wii: Buttons not responding 6. Nintendo Wii: No static, or cracklingnoise or no sound from Wii remote speaker 7. Nintendo Wii: No shaking,vibration or rumbling in remote 8. Nintendo Wii: Batteries drain too fast.How to increase life of your wiimote battery 9. Nintendo Wii: No cursor during game 10. Nintendo Wii: Tilt problems 11. Nintendo Wii: Message "There isno Mii save data on your Wii Remote. Format this save data?" 12. Nintendo Wii: How to repair a wiimote NintendoWii: Sensor bar Problems 1. Nintendo Wii: Disassemble guide -Sensor bar tear down 2. Nintendo Wii: Repairing a broken cableon sensor bar 3. Nintendo Wii: Adjusting thesensitivity on the sensor bar 4. Nintendo Wii: One dot during Sensitivityadjustment Nintendo Wii Power Problem 1. Nintendo Wii: No power 2. Nintendo Wii: The system plays forawhile but then shuts off on its own 3. Nintendo Wii: Power light does notturn on 4. Nintendo Wii: WiiConnect24 Settings Detailed description and fixes to all theerror codes Nintendo wiirepair guide Good luck and happygaming...
I don't have a problem i would just like to ask you can i play nintendo wii games on my GE projection tv
1helpful
When I turn the Wii on it makes no sound
Check to see if the audio cables from the Wii to the TV might have come loose or unplugged.
If you have a friend with a Wii, see if their cable connecting the Wii to the TV works. Your cable might have gone bad.
Our nintendo wii will not play the wii sports
well, it could be a simple problem like the disk in backwards. or something else that maybe might lead to bigger problems.
3helpful
Remote stoped working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
