Question about SkyScan 86709 Atomic Wall Clock
Manual Information/Owner Guide
Where do I find a Manual for my clock so I can set the time & date manualy as it keeps wanting to dispay naval time, My clock is a skyscan digital display of the time. date, moon cycles, and indoor tempeture, wall/ or table top with four setting buttons on back for SET,+,ALM,SNZ, the front is silver frame.grayish/bluish with frame break between time and date,ect..
  • 4 more comments
  • MINO12 Mar 28, 2008
    I HAVE A SKYSCAN ATOMIC CLOCK MODEL 28700 I PURCHASED AT SAMS I CANNOT SEEM TO SET TIME AFTER THE TIME CHANGE IN MARCH. PLEASE HELP. NEED MY CLOCK SOON
  • Anonymous Jun 30, 2008
    I am having exactly the same problem. We lost the manual and can't figure out how to get it to MST. Craftylady4u
  • albschwarz Jul 29, 2008
    Need help to set the day & date.
  • revmichelle Oct 21, 2008
    I need a users manual for Skyscan 86715 to set the clock
  • Anonymous Dec 13, 2008
    Where do I find a Manual for my clock (86715) so I can set the time & date
    manually My clock is a skyscan
    digital
    date,ect..
  • emilybh4 Dec 13, 2008
    digital
    date,ect..
In order to toggle display of Temperature, Seconds, Day of Week, and Month, hold + and press Set once. Release and repeat to move through the various display configurations.
Posted on Apr 07, 2009
    Problem Solver:
  • 7 Answers
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
FixerUpper
Posted on Dec 19, 2008
So where do I get the manual?
Posted on Jun 18, 2008
6ya staff
SOURCE:
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
How to set small clock on right side of home screen
Select 'Menu' then select 'Settings' then select 'Date and time'.
Select 'Date and time settings' to set the date and time.
You can also scroll down in Date and time Settings and select 'Auto-update of time' which means your phone will automatically keep time using your phone network service.
User guide for Nokia 2730 can be found at:
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_2730_UG_en.pdf
Mar 11, 2011 | Nokia 2730 Cell Phone
How top set time/date on AT&T model 1820 answering maching
First, adjust the volume to halfway.
Press CHANGE(the Message Window will display "C").
Press CLOCK(current day setting is announced), hold down FORWARD or REPEAT until correct day is announced, then release the button.
Press CLOCK(current hour setting is announced), hold down FORWARD or REPEAT until correct hour is announced, release the button.
Press CLOCK(current minutes setting is announced), hold down FORWARD or REPEAT until correct minutes is announced, release the button.
Press CLOCK, the new day and time setting is announced.
Here is a link where you can download the manual. This site requires you to rate the product or enter a security code before you can download.
http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1820-_E
Feb 27, 2011 | Lucent AT&T 1820 Corded Phone (23151)
How do I set the inset clock on my vtech 6.0?
"Please set the inset clock" This message keeps coming every time I want to play a phone message stored on the phone. What do I do? Please answer by email. Thank you Jim Lehman lehmanj@myvmrc.net
Jan 21, 2011 | Vtech 9009111 Cordless Phone
I need instructions for changing the clock setting on my 2003 E320 Thank you very much
If your car have the command you must set all the clock function on command take the owner manual an read how to do it all the information in the owner manual if don't have the command, First ignition on, then have a look on steering wheel you have two multifunction switch group on your steering at left and right, get mileage display on press up page key on left switch group, keep eye on instrument cluster display then get setting menu and press up arrow key on same switch group, then use up and down arrow keys to select time and now you have to operate right hand switch group + or - key for increase or decrees time.adjust the time or date you need then then again up arrow key next step will appear time setting will set your time format,
Nov 15, 2010 | Mercedes-Benz E320 Cars & Trucks
I have a i534 serial #crb01408050007498 And during a move I lost the manual that came with the camera and can't remember how to set the clock ? so that it keeps the corect date on the pictures . Is it...
You can download the complete user guide for the camera here >>>>>>>
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/I534-_E
Enter the number code in the box to download the manual and please in future don't put your personal details on the site.
Regards.
Aug 26, 2009 | Polaroid Cameras
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
New daylight savings schedule
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 06, 2009 | Emerson Smartset Clock Radio
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Aug 13, 2008 | Panasonic Microwave Ovens
SkyScan 86709 Atomic Wall Clock Logo
3,666 people viewed this question
Top SkyScan Home Experts
Dave Robertson
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
