Fisher paykel smart drive 703 will not fill -Pulses input solinoid - water is available After empties pulses main motor several times the stops and beeps
see this possible causes: God bless you see the diagrams Lid switch test for defective or open Motor coupler replace coupler motor for defective Belts worn belt Clutch wears replacement Drive motor one winding burn , run with one winding in one direction and another with the other winding. Drive pulleys frozen pulley, worn. Transmission broken gear+ shifter defective Agitator worn agitator replace
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
