Sony CDX-CA400 CD Player Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After market stereo installation help
I have a 2000 vw jetta,it has old school sterop tape player,i want to upgrade to a aftermarket cd player,tell me what totally is needed for the installation ....thank you .
Anonymous
Level 3:
  • Master 2,317 Answers
  • Posted on Mar 14, 2010
Anonymous
Master
Level 3:
Answers
2317
Questions
Helped
787228
Points
7079
You'll an stereo install kit. I comes with the surround for the new stereo to fit into, and that will fit into the space for the stereo in the dash, this kit will also have a connector to wire the new stereo to, and plug into the stock stereo plugs.
2answers
Wire radio color code diagram 2002 Jetta
not told why (the job) rats eat the wires or what?
no country of vin told
nor which of 5 to 10 audio head engine sound system radios
is there now or if aftermarket not from Jetta VW
the USA car this wiring is in the service manual
but is 1 or more page for each of 5 to 10 radios VW used
see???????????
ours are here
https://eautorepair.net/Marketing/Default.asp
welcome to WWW wide world web, where anyone can post
then fails to tell country or VIN, and is 99% of the post here
and the all time reason for wrong answers./
for cars here we
for newer radio
we use these
https://www.scosche.com/car-audio/installation/harness
1helpful
After Market Radio Installation
Hey man, you have an amplified system. use a 70-1858 wiring harness and jump the blue/white wire from the aftermarket radio to the pink wire on the second plug. this will power on the factory amp with the aftermarket radio.
Chris-
Install alpine cde-7856 in 1996 vw jetta
Should be straight forward. Just get you an aftermarket wiring adapter.
4helpful
I have a 2005 Volkswagen Convertible Beetle. The
i am a vw tech there is a fuse on the back of the radio if it is not bad you need a radio now if you go aftermarket when installing the radio clip the brown wire and tape it off or this will cause communication isues with the control modules
1helpful
I need to know how to install an aftermarket stereo in my 1995 vw golf....
go to your local halfords or the likes and you will need to get a wiring harness designed specifically for your car.you will need to tell them what kind of aftermarket stereo you have as the harnesses are all different.
10helpful
3answers
Battery drain
My wife's 2001 Jetta TDI had the same problem. First we changed the battery. (It was just about due anyway) No change. We then traced the power drain to the in-trunk mounted CD changer. This was an aftermarket CD changer but we went to the same source that the VW dealership uses. Of course one blames the other. The CD changer was even replaced with no change. If we are not using the car for long trips we unplug the CD changer and no more dead battery! Neither the VW dealer nor the AV installer could give us a good working solution to this problem.
3answers
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
