I am installing bamboo wood flooring onto my floor. Will I need to lay moisture control first or would the glue be enough? I live in Florida
As we know that during warm and humid summers, hardwood flooring expands & during the dry winter season, it contracts. So, it's extremely important to keep up with hardwood flooring maintenance as per the specific climate. As a homeowner, you should be moisturized during winter time by the humidifier. And during the humid summer weather keep maintain it by using air conditioners or dehumidifiers. Hardwood flooring is made from domestic woods; so have the combined digital temperature/moisture meter in order to monitor indoor conditions all year round.
You wont need a moisture barrier if its a wood sub floor but if its a concrete sub floor you probably need one. you can do a simple moisture test on concrete by taking a clear plastic cup, put silicone around the rim and stick it to the floor overnight. if there is moisture droplets in the cup the next morning then you need a moisture barrier. do this in a few spots through the area wood flooring will be installed.
Good dry concrete should be white in color and no musty smell.
You need moisture control if laying below ground level or on concrete anywhere as concrete is porous
Bamboo flooring is much more resistant to moisture than most solid hardwoods. you should still never leave liquid on it for an extended period of time in order to protect your floor.
The main advantages of bamboo flooring are its durability, and the fact that it is sourced from a renewable resource. Moreover, bamboo flooring is much more resistant to expansions than solid wood and is also insect resistant.
First, you can get the exact visual design that you wanted
and it will cost you considerably less. Second, laminate flooring can be
installed above and below the grade unlike hardwood flooring. Moreover, the
laminate flooring is installed without using any nails or glue which make it
much easier to it yourself. Furthermore, laminate flooring is extremely
durable, easy to maintain and can be replaced easily.
