Whirlpool GGQ8831L Gas Dryer Logo
Posted on Oct 22, 2017
Whirlpool Ultimate care II dryer,burns dark clothing all the time
Whirlpool Ultimate care II dryer is working fine but seems to scorch my dark clothes. The majority of black clothing comes out with permanant brown marks as if the dye of the clothes has been removed. Most clothes this happens to. I dry on a med heat. Normal cotton or delicate never above & clothes are not excessivley hot to remove???????
1 Related Answer
Anonymous
  • 67 Answers
  • Posted on Oct 28, 2008
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
I have a Whirlpool Ulitimate II Washing Machine problem. Model LSQ9010KQ0 Serial CM2756127 Type 111. Seems to be working fine expect that after the spin cycle the clothes are still pretty wet. Water is...
It sounds like what you're describing is a weak clutch. The clutch could be worn & slipping or may have oil residue on the clutch pads. I would recommend replacing the clutch. Here is a link to the part.
5helpful
Drum doesn't turn
Check this out
Bonus
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
3helpful
Burning smell
Stop using the dryer! You are probably close to having a fire if you continue to use it. The whole vent system should be taken apart, cleaned, the heat limit sensors checked and the duct cleaned. Your dryer is overheating and is a danger.
Aug 11, 2009 • Dryers
3helpful
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
