Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Anonymous Posted on Jan 03, 2010
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE it is desplaying f-1-
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1481
Points
I cleaned my oven and now the door won,t open. The lock light is flaching.
Dan Webster
Level 3:
  • Frigidaire Master 8,221 Answers
  • Posted on Jan 03, 2010
Dan Webster
Frigidaire Master
Level 3:
Answers
8221
Questions
5
Helped
2380920
Points
25840
F codes
electric oven
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
How do i unlock door on frigidaire stove
Thank you for your inquiry, friend!
You can perform a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If your control panel has a cancel button hold that down and that should release the door. If those steps do not correct the issue please comment back and I will be happy to assist you further. -Matt
Unlock frigidaire professional series
Good Morning Anonymous, thank you for your post!
Based on the symptoms you are describing, it appears that your Frigidaire range is possibly locked. Typically, the "Door Locked" light will glow until the Self-Clean cycle has completed or the oven temperature has cooled. However, if the issue continues, please confirm that the Oven Control Lockout feature was not accidently selected (on some models). If so, you can cancel this feature by pressing CLEAR/OFF and hold for approximately 10 seconds. The control will unlock the oven door and resume normal operations.
If the instructions above do not solve the problem, may I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can determine if your range is possibly experiencing other issues. Thank you - Z.
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
1helpful
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
1helpful
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
2answers
White westing house stove cant open oven door
try pushing self clean then cancel or stop/clear
9helpful
3answers
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 • Ovens
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
