Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost. Here are the steps for unlocking a BB Curve 8520, 1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections. 2 - Go to Settings. 3 - Go to Options. 4 - Select Advanced Options. 5 - Select SIM Card. 6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD), 7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2), 8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm, 9 - Your Blackberry 8520 Curve will now be unlocked.
Guzzle,
Yes, you are correct in assuming that the schemes for BB are expensive. And all are available to you much cheaper in GPRS schemes.
The settings would be sent to you immediately after the service of GPRS is activated on your number. If not then you can dial MO to 121, free. You will receive an sms asking you to save the sms. Save it and the settings are configured. BUT remember to delete the MMS and Airtel Live from your phone settings as they are really expensive to use. GPRS is cheap. And advantage in Airtel is that there are no roaming charges on data access. Means that you can access the net from anywhere in the country free if you have an unlimited usage plan.
However, the settings are as under,
IP address - 202.56.231.117
Proxyport settings - enable
Proxy port number - 8080
APN - airtelgprs.com.
You give it the name of Mobile Office.
And you can have any home page.
